GMT400 Wiring Questions
I've searched high and low during the last seven months of this project and have found some great projects (Jeebalow, Green95Hoe, amongst many others) and some great written info (S&P's 13pg PDF), hell not to mention Brendan's amazing write up on lt1swap.com. With all of that great info, wiring the two harnesses has been glossed over for whatever reason(s). But that's ok, I guess with whoevers help I will fill in the blanks.
Ive posted this question on many of those fullsize sites, and not one person has the answer for me. Not one reply. So I heard this place has answers, I thought Id try here.
Thanks in advance.
Nick
As far as the ABS goes, I'm pretty sure it has its own computer. But that's exactly the info I need too.
Good luck with your swap. I appreciate you chiming in.
Nick
http://www.gmt400.com/forum/showthread.php?t=31954
Nick
I will definitely follow this guy. I am getting started on mine now. The old drivetrain is gone and I am starting to strip the wiring from the l83. After a lot of research I believe I am removing the antilock brakes. They are said to give a lot of problems in my year truck, so I dont need the old computer.
Again, best of luck!
I just have some questions regarding where some wires go that are connected to the '95 C100 connector.
Any help would be appreciated.
