S-series swaps!
Old Oct 27, 2015 | 08:15 PM
LSLucas's Avatar
Default S-series swaps!
How many 95 and up S-10's, blazers, sonomas or jimmys are there on here?! I'm in the process (slowwww process lol) of building a 98 2wd, 4dr Jimmy with a turbo'd 5.3 on SBE amd was curious if anyone on here had an s series with a turbo setup?
Old Oct 27, 2015 | 08:53 PM
Beanslsxnova's Avatar
There a few of them floating around that I've seen over the years. I know silver82 has a nasty 8sec twin turbo s10. There's another guy with a big single turbo s10, I'm not sure of his screen name. Speed inc built a twin turbo typhoon a few years ago. I'm sure if you search turbo s10 it will bring some up
Old Oct 28, 2015 | 01:31 PM
no green's Avatar
Here's my jack stand warrior. 96 2wd, 4dr blazer 5.3 76m some-daily....
I took it apart before cell phones had cameras
Old Oct 28, 2015 | 02:47 PM
DavidBoren's Avatar
Silver82's twin turbo dime is a first gen, doesn't quite qualify for '95-up in this regard. But that thing is fast!
Dude on here just completed a ls1 swap into an Isuzu hombre, might want to check it out, given it's the same platform as the gen2 dimes.
I will be watching this to see who all shows up, because I, too, have an S10 and plan on equipping it with a turbo LSx.
Old Oct 29, 2015 | 01:47 AM
MrPotatoeHead's Avatar
What is that filler neck on the power steering off of?
Old Oct 29, 2015 | 06:51 AM
no green's Avatar
It's from the 4.3 out of the blazer. Modified the tab on top a little, and drilled a hole in the alternator bracket. It has a dipstick, too.
* as a matter of fact, it's the pump out of the blazer, too. It plugs right in the truck brackets.
Old Oct 29, 2015 | 08:37 AM
rpturbo's Avatar
I have my 94 SS done. 94 is the first year of the second gen. I am working on doing a turbo in the spring.
Old Oct 30, 2015 | 12:25 PM
gols1go's Avatar
Here's my piece of junk.....
Old Oct 30, 2015 | 12:46 PM
gsteele's Avatar
Thanks for sharing. Let us know how that works for the down pipe cut out in the passenger foot well. Did you carpet over the metal work, how does it look and affect the passenger etc.
Old Nov 3, 2015 | 11:38 AM
BudRacing's Avatar
Lots of S-series swaps out there. They're practically bolt-in these days unless you want to keep the AC compressor in the factory lower accessory position.
I remember there was a pretty mean pewter 2dr blazer with an LQ4 turbo swap running 10's several years ago. I was debating picking it up for 8k and selling my own at the time, but someone else beat me to it and fixed it up even more.
