Breather tube question.
Old Nov 7, 2015 | 05:17 PM
LSLucas's Avatar
Default Breather tube question.
The breather tube hose for the heads on my engine ran to the throttle body. My question is since I'm putting a regular intake with a throttle body elbow and a throttle body, how will I need to run my vent tube?
This is the tube like me
This is what I'm gonna do
Old Nov 7, 2015 | 05:40 PM
nofun's Avatar
Those are your steam port tube, you will need to keep them. You can run a hose back
to the radiator
Old Nov 7, 2015 | 05:45 PM
tfi racing's Avatar
Many possible solutions,some drill and tap the water pump,others put a tee in the upper rad hose,here's mine.
Old Nov 7, 2015 | 09:37 PM
bczee's Avatar
I bypassed the connections on the Throttle Body and run it directly to the Radiator.
You can also simplify the setup and use the LS6/LS2 setup, which just uses block on the back two and just has the front joined and connected to the radiator/water pump/hose.
BC
