LS9 supercharger in a 2002 35th anniversary SS
Just like the title state. I'm in the process of putting a LS9 supercharger in my 35th anniversary SS. I'm currently going to use my stock ls1 block with this setup. Once I get it running and all the bugs worked out I will swap the ls1 out for a Ls3.
The V crank pulley is on the Vette spacing. Not sure how you would go about making your current accessories work. You could always get a cts-v FEAD since the parts are in the same location, just set back at corvette depth.
I thought the vette and 4th gen Camaro had the same spacing?
The heads are L92 heads with the stock intake valves and the exhaust valves are smaller. The Intake valves clear the cylinder walls but the exhaust wont. So I went to a smaller set of exhaust valves so I could get it to run. Right now all I want to do is get the charger in and setup and down the road I plain on putting in a ls3 or maybe a ls7 block. but for now I'm using my stock 5.7. So yeah right now zero ***** are given lol
