6L80E Wiring Thread
Old Jan 26, 2016 | 07:50 PM
12SEC SS's Avatar
I did this very same thing last year for a friend. played with settings in hptuner, and even though i got it to correctly recognize the shifter in S mode, TU/TD still would not work. took the same computer, programmed it like a 2009 Corvette, and it started working right off the bat. in the truck, these things go through the BCM.
Eithere wire and use the BCM, or switch to a corvette OS. I can give you a hand if you need, PM me.
Old Jan 26, 2016 | 08:00 PM
GENIIIDude's Avatar
An 09' has a different ecm than a 2014 pickup, does that matter with the OS?
Old Jan 26, 2016 | 08:01 PM
GENIIIDude's Avatar
wouldn't I need an OS from a 2014 and up corvette that is DI?
Old Feb 22, 2016 | 01:25 PM
firestrait's Avatar
My laptop, print to PDF. Have requests?
Hi
I could have use for 2013 Camaro SS 6L80E schematics... And also for that L99 and LS3 engine schematics...
I bought complete engine/trans pullout from '13 Camaro. I have gas pedal, ECM that controls also trans.
Now that L99 engine is converted to LS3 and several wires are useless... We have to modify that original harness... I also did a new thread for that but if this message reaches you and you could help me... That would relieve my headache..
Keeping my thumbs up
I have had several sleepless nights because of this.....
Old Mar 23, 2016 | 04:13 PM
firestrait's Avatar
Hi again.. I'm making progress but can someone help me with those two pairs of wires that comes from gearbox... Those are "computer data lines system" and I don't know what to do with those... I assume that in Camaro '13 those pairs goes to Body Control Module, but I don't have that in my oldie...
Are those just GMLAN high wires and in my situation, could I just end them or what?
Old Mar 23, 2016 | 08:56 PM
12SEC SS's Avatar
Use them to go to obd2 port
Old Apr 18, 2016 | 11:59 AM
68FirebirdAP's Avatar
GENIIIDude,
Were you able to confirm if the TCC brake apply wire goes directly to the TCM or if that is communicated through the CAN BUS? I traced the blue/white wire from the ECU to the brake switch and the BCM going to the tail lights, but I cant find anything tracing it back to the TCM connector.
12SEC SS,
Can you PDF the TCM wiring drawing and PCM pinout for a 2012 Tahoe 5.3 & 6l80?
Old Apr 19, 2016 | 08:25 PM
12SEC SS's Avatar
Exclamation
2012 Tahoe 1of6.pdf
2012 Tahoe 2of6.pdf
2012 Tahoe 3of6.pdf
2012 Tahoe 4of6.pdf
2012 Tahoe 5of6.pdf
2012 Tahoe 6of6.pdf
Pin 6 on the trans connector is labelled Brake Sw Sig
Old Mar 15, 2022 | 12:00 AM
torky's Avatar
Default hi there
i got 2010 silverado 2500 hd 2wd with 6l80 ,
i replaced the transmission after damage with 6l80 2wd out of 2009 escalade
now all gears working but speed matters not working and p r n d m not selecting any of them and also light of reverse not lighting when it move reverse
i hope someone help me please
Old Nov 10, 2025 | 04:08 PM
Dyl432's Avatar
are you able to get me the same graph for a 2017 Silverado 1500 LT 6l80
Old Nov 10, 2025 | 08:30 PM
He hasn't been here for over 3 years. Check post dates
By Brett Foote | 2026-06-04 05:00:17
