6L80E Wiring Thread
Old Jan 17, 2016 | 01:46 PM
GENIIIDude's Avatar
Default 6L80E Wiring Thread
Ok - I've started this new thread to figure out a puzzle - I have at least three different 6L80E wiring diagrams and I do not think any of them are correct for the 2014 version. My setups converter is not unlocking.
The 2014 6L80E I'm working with has three wires from the ecm - Brake apply power supply, brake apply signal, and brake apply low reference.
On previous version 6L80E's there is only one wire (that I have found in pinouts), the brake apply signal which takes a constant keyed 12v and no voltage when brake is applied.
Also - previous pinouts of the 6L80E say that there is B+ and keyed 12v - the 2014 I have only found a B+.
Does anyone have or have access to the 16 pin connector pinout on the 6L80E trans? And have any experience in wiring the brake signal to the ecm?
This is what I've found:
Thanks in advance for the help!
Old Jan 17, 2016 | 02:40 PM
12SEC SS's Avatar
what car/truck is this trans from?
Old Jan 17, 2016 | 02:46 PM
GENIIIDude's Avatar
2014 Silverado 1500
Old Jan 17, 2016 | 05:39 PM
12SEC SS's Avatar
Originally Posted by GENIIIDude
2014 Silverado 1500
see if this helps
2014 Silverado 1500 Transmission 1of2.pdf
2014 Silverado 1500 Transmission 2of2.pdf
Old Jan 17, 2016 | 07:47 PM
GENIIIDude's Avatar
Thanks!! Great info, they match what I'm seeing in my harness. I found the 12v keyed, it was already powered through another circuit that ties to it. The main issue I'm still having is the Brake Signal circuit.
ECM X2 - pin 47 - Brake Apply Sensor Supply Voltage
" " " - pin 48 - Brake Apply Sensor Signal
" " " - pin 68 - Brake Apply Sensor Low Reference
Which one hooks to 12v until brake pedal is pushed?
Old Jan 17, 2016 | 07:57 PM
GENIIIDude's Avatar
Originally Posted by 12SEC SS
In the first schematic I posted it shows the brake switch signal at pin 6 of the trans plug. This must be a different year/model of application.
On the first schematic you posted it shows pin 6 empty and in my trans plug pin out it is actually empty. Soooo, I have to assume on my application the Brake apply data is sent over the CAN network from the ECM to the TCM?
Old Jan 17, 2016 | 08:08 PM
12SEC SS's Avatar
I dont think you need to worry about those 3 pins and that brake sensor. looks like its there to tell how hard youre pressing the pedal, likely its more for abs and/or traction control.
pin 57 on X1 looks to be what you need.
2014 Silverado 1500 Engine 1of6.pdf
Old Jan 17, 2016 | 08:34 PM
GENIIIDude's Avatar
Attachment 525001
Good catch - been over those pin outs a million times and missed that! It should have keyed 12v until the brake pedal is pressed then no voltage? Thanks a ton!
Old Jan 17, 2016 | 08:48 PM
12SEC SS's Avatar
Yep. Get a brake pedal switch from something gym late 80s with cruise control, like Camaro.
Been there myself, eyes start playing tricks after a while staring at wires
Glad I could help
Old Jan 17, 2016 | 09:33 PM
GENIIIDude's Avatar
Glad I could help
Where are you getting your schematics?
Old Jan 17, 2016 | 09:37 PM
12SEC SS's Avatar
My laptop, print to PDF. Have requests?
Old Jan 17, 2016 | 09:47 PM
GENIIIDude's Avatar
Of course! All of the 2014 silverado engine/trans schematics! Please....
Also, could I do this instead of the brake switch?
Old Jan 17, 2016 | 09:49 PM
GENIIIDude's Avatar
That schematic is from LT1Swap.com - These are their words:
"Brake Switch Signal - For automatics with lock up converter, the PCM needs signal when brake pedal is pressed. However, the signal needed is opposite how you're brake lights work. The PCM wants 12v+ constant on this wire when brake IS NOT pressed, and OPEN Circuit when the brake IS pressed. If you vehicle was equipped with a lockup trans to begin with, you probably already have the proper normally closed switch mounted by your brake light switch. If you do not, you can use a relay to perform the same thing. On most relays, there are 5 terminals, 2 of them turn the relay ON when provided ground/power. There are then a normally open leg and a normally closed leg on the relay and a supply. By feeding 12v+ on the supply leg, and hooking the Brake Switch Signal wire to the normally closed leg, you will now have the correct signal for the PCM. When the brake is pressed, 12v+ flows to brake lights, tap into this wire, and run it to the relay to turn the relay on. This will cause the normally closed leg to become open, thus turning OFF the 12v+ signal to the PCM. When you release the brake pedal, the relay will turn OFF, and then feed 12v+ to the PCM."
Old Jan 17, 2016 | 10:04 PM
lizeec's Avatar
What I think 12SEC SS is suggesting on some of the 80's G.M. brake light switches on cruise control equipped cars have 4 terminals, it can be wired where 2 of the terminals are NO and the other 2 terminals are NC, so you can use it to de-activate for a the lockup converter, eliminating the need for a relay.
Old Jan 17, 2016 | 10:47 PM
12SEC SS's Avatar
The relay would work, and i was suggesting a GM cruise control switch to replace the one you currently have. I am a firm believer that a part thats not there doesnt break, so my swaps use the gm brake switch with extra terminal.
diagrams attached.
2014 Silverado 1500 Engine 2of6.pdf
2014 Silverado 1500 Engine 3of6.pdf
2014 Silverado 1500 Engine 4of6.pdf
2014 Silverado 1500 Engine 5of6.pdf
2014 Silverado 1500 Engine 6of6.pdf
Old Jan 18, 2016 | 01:31 PM
1989GTA's Avatar
I had the same problem with my 6L80 install. First I had to get the brake switch wiring correct. I did that but it still did not work with my after market Yank converter. Come to find out the signal to lock up the converter was there but there was not enough pressure applied. So the tuner upped the pressure and all was good.
Old Jan 18, 2016 | 07:38 PM
GENIIIDude's Avatar
I agree, just looking at other options! Thanks for the schematics!
Old Jan 25, 2016 | 09:50 PM
GENIIIDude's Avatar
Ok - Tap up / tap down is hooked up, but not working. Here is a screen shot of my HPTuners. Anybody got any idea if I have everything in the tune correct?
Old Jan 25, 2016 | 10:53 PM
12SEC SS's Avatar
Start with basics, what are you using for shifter? What os in the pcm? I've plaid some with it before, and for the 1 wire tu/td to work I had to use like a 09 vette os. Log the extra pid's in hptuners scanner, and see if you're registering shifter in S mode. I can look up more info tomorrow if you need.
Old Jan 26, 2016 | 07:40 PM
GENIIIDude's Avatar
Shifter is the one from speartech, I believe it is from a G8. The OS is the stock os from a 2014 GMC Sierra 1500.
