PCM 411 not reconizing A/C Pressure Sensor
Has anyone ever ran across this situation. I have a 411 PCM with a tune from a 2002 Chevy Express Van . Also I have a Vintage Air A/C system installed in which I wired to use an A/C pressure sensor (22664328) in order for the PCM to control the A/C unit . I changed my AC Type in the tune to analog , The fans and A/C clutch relay comes on when the engine is running, everything appears to work OK except for the A/C pressure Sensor. The fan and A/C clutch relay works whether or not the A/C pressure sensor is installed . Can't figure out why the PCM is not looking for the output from the A/C pressure sensor. The A/C pressure sensor is wired C2-14 red , C2-57 violet , C1-45 gray , A/C clutch relay coil C2-43 and relay contact to C2-18 just like the 2002 Camaro. MY understanding is the PCM should not turn on the fan and A/C clutch relay unless it see the output from the A/C pressure sensor and the engine is running at 550 rpm.
Any help is appreciated
The 411 vans that I have seen schematics for all used a high and low pressure switch setup instead of the truck/f-body style pressure sensor. What OS # are you using?
The 411 ecu was being used with trucks/vans with 2 wire pressure sensors and the 3 wire in fbody/vette with variable displacement compressors.
There's also the issue with DBW (used in trucks and vettes) and cable TB (used in trucks anf F bodies).
If you're looking for a stock tune, you might want to keep these consistent.
Good luck, when you get it working it is great (just like the factory!!!)
Ricky
I run 1 fan of the ecu temp, the other off a trinary switch and/or ecu engine temp control.
Thanks for the info.
