MY 1960 Chevy Parkwood LS1 swap cammed
Got the axle painted.
Had to weld on a tab to hold the brake line tee.
bent up new hard lines and got the axle installed.
Just waiting on the salt to clear off the roads to go out and do some burn outs.
Nice build! Wondering what you did for your throttle cable and pedal. I 5.3 swapped my 60 Bel Air and I haven't found a good way to mount a throttle cable since the pedal comes through the firewall right behind the head. I was just wondering what you used for a pedal or throttle cable! Thanks!
I used all lokar stuff. They dont list that they have a pedal for our cars, but a 1969 camaro pedal goes right in. Then use the cable they list for an ls1. i can dig numbers if you cant locate them.
Awesome! I should be able to find it, I just needed to be pointed in a direction. I looked into the Lokar universal pedals but they are expensive and I wasn't sure I wanted to take the risk and have it not work out. For the 69 Camaro pedal does it go through the firewall in the same spot or did you have to cut a hole? Being right behind the head kind of sucks!
Awesome build i PM'd you on 67-72 small world my 59 build is on here somewhere but alot of my pics dont work anymore anyway Love the orange paint very clean build can't wait to see it in person
