Project: Money Well Wasted
I have a 1986 GMC S-15 Base, Standard Cab, Short bed, 2wd. Was a Manual trans, 2.5l TBI. Manual brakes, Manual steering. No rust, Engine, Trans, Radiator or grill. I bought it because it was a cheap start at only $200 for it.
I have been reading and reading for the past year on LS engines. but till got some questions that seemed to not be answered because I can not find them in my stack of notes.
I am working on a budget... I know everyone says that. and no one really gets the cost until you start it. But I am trying to gather information due to lack of some things that seem required.
I want to share something about the drivetrain in question for the swap.
2000 Chevrolet 3500, 2wd, std. cab, long bed, 6.0L with 4l60-e trans, IT has been wrecked. hit a tree on the drivers side cab. can not be put back on the road. it runs, drives, stops. dash is busted up, no gauge cluster.. For $1600 seems like a steal with only 96K miles.
Problems I have discovered from reading.
I cannot notch the frame. Lack of welder, knowledge.. I do not know anyone who could do it. or for what cost. I have talked to a few welding shops in my area and they said that they refused the work due to structural integrity. if I wrecked the truck I could say the crossmember broke. yadeeyada. so issues.
I wont be running a/c so if I read/understand I shouldn't need to notch the frame. Correct?
I do not plan on running power brakes unless I can use the brake booster/master/abs from the 3500 witch I doubt it. but just in case. will I have problems with not using the brake booster? Vac leak?
No power steering, I understand it will be a pain to steering with the weight. but for the moment it will work. unless I can use parts from the 3500.. witch again I doubt.
If I understand I can use a 4.3l radiator with e-fans. The donor has the rad/fans complete cooling system in it.. will they interchange? modifications?
I am also wondering if anyone has used the ebay LS mounts? when I bought the truck I got a brand new set of 2.8l mounts so all I need is the engine side. just curious.
Wiring is always a pain. but I can figure it out thanks to research n a few forums. but might run into some problems. there is always problems.
The donor truck has the complete fuel system/emissions everything. what can I re-use? will the intank pump work in mine? any ideas?
So in the end. what can I re-use?
Thank you everyone fr reading. hope to buy this truck depending on the answers.
