67 Chevelle, best fitting trans for LS???
Old Jan 27, 2016 | 10:25 PM
gpracer15's Avatar
Default 67 Chevelle, best fitting trans for LS???
Thinking about installing a 6.0 LS engine but which trans fits the tunnel better? 4L80E or 4L60E? 6L80E?
Manual 5 or 6 speed out of donor car???
New one piece floor and trunk pan just installed, would prefer not to cut but upen to it if i know where and how much gets cut
Plan on using oem BB frame mounts and engine mount with DD sliders when i get to that point.
Any suggestions, info, pics appreciated.
Old Jan 27, 2016 | 10:39 PM
oldngray's Avatar
Default trans
The 4l80 is big and the 6l80 is HUGE, with some minor mods to the tunnel the 4l80 might work for you, the 6l80--- get out the cutoff wheel
Old Jan 27, 2016 | 10:49 PM
gpracer15's Avatar
Yep thats what i thought.
Lots of option i just want to get the right parts the first time.
Mounts
Headers
Accesories
Etc
Old Jan 28, 2016 | 04:45 AM
Alwhite00's Avatar
My 4L60 barely fits, A 80 would need major surgery.
Old Jan 28, 2016 | 07:07 AM
1964SS's Avatar
4L60E would be the best fit. The others are much larger. The T56 is also very large and requires cutting the tunnel up.
Old Jan 28, 2016 | 03:44 PM
gpracer15's Avatar
I got a line on a low mileage LS 6.0 and 4L60E combo from a Silverado.
Going to look at it tonight, anything to look for? Best head numbers or all the same?
Old Jan 28, 2016 | 09:31 PM
Alwhite00's Avatar
The 6.0 came with a 4L80 stock so either it's not a 6.0 or it's a 4L80.
Old Jan 28, 2016 | 11:21 PM
gpracer15's Avatar
Well i didnt look that close at trans. Block had 6.0L on it
Old Jan 29, 2016 | 10:21 AM
jsanford's Avatar
What series Silverado? The HD trucks came with the 4L80E. But some of the performance Silverado's with the 6.0 came with a 4l65e.
Old Jan 29, 2016 | 11:03 AM
hookemdevils22's Avatar
1999-early 2001 6.0s had iron heads. Check the fron of the passenger-side head (pic for reference) or rear of the driver's for a "317" casting number, which are the aluminum heads. If it is indeed mated to a 4L80e (which should be stamped on the trans; the '80e also has two speed sensors, while the '60e only has one), the crankshaft likely (though not certainly) has a ~.500" flange (reference), which limits transmission options.
Silverado 2500s came with the 4L80e; starting in ~2004, 1500s with the 6.0 received the 4L60e. If it's indeed a 6.0L/4L60e, it should have an ECU with blue/green connectors and I believe would be drive-by-wire.
I initially put a 4L80e in my Nova without major modification before swapping to a T56, which was a major, but immensely satisfying, undertaking.
Old Jan 29, 2016 | 03:49 PM
gpracer15's Avatar
I found our he bought the 6.0 and the trans from same place but requested the 4L60e.
2005 Silverado 6.0, im betting a LQ4. 22k miles
All acc, stainless headers, edelbrock single plane carb intake.
He wants $2000 for both
Only thing i dont like is that he painted the block and heads black. How can i get the paint off the heads without tarnishing the aluminum?
Old Jan 29, 2016 | 07:59 PM
Mikes64's Avatar
My 03 6.0 out of a Hummer had a 4L65
Old Jan 31, 2016 | 06:36 AM
Alwhite00's Avatar
That's a good price on that setup.
