tach wiring
Old Jan 31, 2016 | 09:30 PM
Seeker1056's Avatar
Default tach wiring
didnt have much luck with search
I read somewhere but cant confirm that the LS pcm requires the tach to be set on 4 cylinder to read correctly?
can anyone out there confirm what tach setup i need so I can reinstall my dash?
thanks
Old Jan 31, 2016 | 11:08 PM
G-Body's Avatar
sawzall wielding director
If the LS1 pcm tach settings are left stock from GM you would have to set the tach to 4 cylinder. You can also use HPTuners, efilive7, etc to change the PCM tach output to whatever you need.
