dbw to dbc
Old Jan 25, 2016 | 02:22 AM
Streaty383's Avatar
Default dbw to dbc
How easy / what's required to swap an l98 to drive by cable? Planning on running an l98 in a Silvia for a drift car
Old Jan 25, 2016 | 03:36 AM
ls1nova71's Avatar
I thought the L98 was a TPI engine? Do you mean L99?
Old Jan 25, 2016 | 05:06 AM
Streaty383's Avatar
Not sure if they were used in the states but we had them here in aus, 6l with rectangle heads.
Old Jan 25, 2016 | 07:24 AM
garys 68's Avatar
This should help:
http://www.lt1swap.com/cable_conversion.htm
Old Jan 25, 2016 | 10:10 AM
ls1nova71's Avatar
So I'm going to guess it's a GenIV? That makes it harder to go DBC than the older GenIII.
Old Jan 25, 2016 | 12:25 PM
Project GatTagO's Avatar
You can easily do it with a Holley HP system.
Andrew
Old Jan 31, 2016 | 10:17 PM
Forcepower's Avatar
a 4th gen camaro harness and a lingenfelter converter box will work also.
Old Feb 1, 2016 | 03:13 AM
S2KIWI's Avatar
Prettty sure you will be using the E38 which doesn't support it natively. Same issue for me with an HSV sourced LS3.
You need that converter box, airflow sensor, ls1 ECU etc.
Or do a 24 tooth swap and run LS1 ecu + sensors.
