Weird Fuel Pressure with Walbro 255
I've got a 1999 LM7 in my 240SX. I've been driving it for nearly a month with no real problems except when I drive it for about an hour or longer. It doesn't want to hot start.
I put a fuel pressure tester on the car yesterday on the drive home, and I think it's doing some weird stuff off-throttle.
Driving on the interstate the pressure is about 50. If I go WOT in 5th, the pressure jumps up to 60ish, then goes to ~48 when I let off the throttle.
I've seen some other fuel pressure videos for LS1 swaps and they normally are higher at cruise then drop a bit under throttle. This is what my car does at idle.
Maybe my FPR is bad or my new Walbro (Installed early January) is weak?
