Speed Engineering A Body LS headers
Old May 9, 2016 | 05:30 PM
evldoer's Avatar
My magnet sticks to the flange and the bung pretty hard, and I have worked with enough stainless to know the difference. Cutting, welding, and machining. The primarytubes must be grade 304 stainless
Old May 9, 2016 | 05:37 PM
user 4737373's Avatar
Nickel plated steel would be my guess.
Old May 10, 2016 | 03:13 PM
evldoer's Avatar
Yes Todd, plated steel is my guess on the flanges. Not a deal breaker for me.
On to my update. Here is some pics of the headers installed with the frame mounts I fabbed up. First pic is the pair of mounts.
Passenger side header has about 1/8 - 3/16 clearance to the frame. I did not need to dimple this set of headers on any of the tubes.
The last 2 pics show the ground clearance, which I am satisfied with, and the oil pan to crossmember clearance.
I'm not using the factory brake proportioning valve, but it looks like it wouldn't be a problem if it was there. You can see the original brake line in one of the pics that goes to the rear. When I removed the valve I left the line hanging. This will be removed when I make new lines. I'm using a truck oil pan that had the bottom shortened up to fit a different chassis. I Wil need to modify the pan for clearance with the tie rod ends.
I thought about buying the Holley oil pan for this car but it will only take me 2 or 3 hours to modify this one so that's the rout I'm taking
Attached Thumbnails Speed Engineering A Body LS headers-20160510_115509.jpg   Speed Engineering A Body LS headers-20160510_124544.jpg   Speed Engineering A Body LS headers-20160510_124604.jpg   Speed Engineering A Body LS headers-20160510_124648.jpg   Speed Engineering A Body LS headers-20160510_124718.jpg
Speed Engineering A Body LS headers-20160510_124751.jpg   Speed Engineering A Body LS headers-20160510_124840.jpg
Old May 10, 2016 | 03:44 PM
Plated flanges are certainly functional, so as long as you know what you're getting up-front I don't see any issue with it myself either. At the price point you paid you have to expect a trade-off somewhere and it sounds like you ended up with something you're satisfied with. The exit angle of tubes out of the flange on the driver side header (especially the rear tube) would be the biggest issue for me, but then again I would over-look it if I were shopping with a budget as my primary consideration...well done.
Old May 10, 2016 | 06:09 PM
LLLosingit's Avatar
Yep you are correct, I just checked a set on the shelf and the magnet does indeed pull hard, The Stainless works set sitting on the shelf don't pull at all.
Old May 11, 2016 | 09:34 AM
BoozrCruzr's Avatar
I've yet to install mine in my 1977 Pontiac Can Am. I've been trying to keep the car assembled for the Power Tour in a month or so. All the pics you guys have posted look great! They still look like WIN to me!
Old Mar 26, 2017 | 08:43 AM
Jarred Hitchens's Avatar
Originally Posted by jchevy
I am in the process of installing these in my 68 cutlass. I am using the lsx inovations motor mounts that move my lq4/4l80e forward one inch...
I had to notch the cross member under the motor slightly on both sides to clear...not much no big deal in my situation. I also had to cut part of the bellhousing inspection cover around the starter to clear...again no big deal.
The only complaint i really have is that there was an interference with a boss on the block just below the driverside head right at the back of the motor. I just took a grider to it and clearanced the corner of it.
There appears to be plenty of room for the brake proportioning valve on the driverside frame rail. Ground clearance looks good, its just a little bit lower than the motor cosmember. Steering shaft does not seem to be an issue.
For $300 shipped they appear at this point to be worth it to me....i dont have the body on yet but i dont for see any issues.
If the motor was not moved forward i think the cross member would have been fine...i also dont think the 4l60 will have the inteference issue
How's your swap coming? I'll be starting my swap into a 68 also. I'm curious as to how the headers fit. And did you switch your motor mounts to sbc?
Old Mar 26, 2017 | 02:56 PM
jchevy's Avatar
My swap is running and have a few hundred miles on it so far. Using sbc motor mounts and frame stands. The sbc motor mounts wont fit the olds motor mount brakets.
Headers are decent for the money. I ended up having the massage the the driverside exhaust since its held in so tight to the trans i has shifter linkage interference.
I would buy them again.
Old Oct 17, 2017 | 08:48 AM
jeffs55chevy's Avatar
i have the speed engineering a body longtube 1 3/4'' headers, on my 69 chevelle. 5.3 lm7 muncie 4 speed.
im using lsx innovations motor mount plates in the stock sbc location. the headers fit great very happy with them. the only issue was i had to modify the floor pan on the passenger side for the o2 sensor to fit without hitting the floor.
im running a z bar for my clutch which is not hooked up yet, and that looks like it might be a little tight, but workable. i should have that figured out this week.
Old Oct 17, 2017 | 08:55 AM
JoeNova's Avatar
Restricted User
I've run a few sets of their headers. They are my go-to. Never had to dent or modify them.
My only complaint is that you can't get them with collector flanges.
Old Oct 19, 2017 | 02:34 PM
1964SS's Avatar
Put a set on a 1966 Chevelle. With the LS1 sitting in the factory bellhousing location we had to put some dents in them to fit without hitting, but for the price they are a great header and I will use them again and again.
Old Oct 20, 2017 | 08:16 AM
  #32
LT194CamaroZ's Avatar
Which mounts and frame stands did you use? Curious about these headers and using the trans dapt 4592 swap mounts in my '65 skylark
Old Oct 22, 2017 | 12:01 PM
  #33
heres a few pictures of the speed engineering headers on my setup. 69 chevelle lm7 4 speed muncie.
lsx innovation mount plates part # al11 in the stock sbc location. holley 302-2 oil pan. homemade clutch pivot ball stud bracket for the z bar. the adjustment rod for the clutch fork just barely touches one of the pipes, but i have a nut on the outside of the rod, so i might mess with that, before i dent the pipe.
Old Jun 7, 2018 | 08:25 AM
  #34
chuckd71's Avatar
I just put these in my car since I found some locally and Hooker pieces wouldn't get here before I move. With the engine slid back pretty far (say 1" between passenger head and firewall) they clear everything with both Hooker and Dirty Dingo slider engine mounts. They fit better with the DD mounts since they are a bit taller, but still clear everything - barely in places - with the Hooker ones. I was very surprised with how well everything came together, especially for what they cost. They do hang low however so I'm still going to get the Hooker ones eventually.
Old Jun 7, 2018 | 05:16 PM
  #35
jarheadl34's Avatar
Hey Chuck do they hang lower than the front cross member?
Thanks
Jarhead
Old Jun 7, 2018 | 05:31 PM
  #36
LS1 TJ's Avatar
A bit off topic but I purchased a set of Speed Engineering long tube headers for my 68 C10 LS swap. Fit was right on.
Area for improvement on the header design is on the exit on the tube from the head flange. Needs a bit more or longer radius for best flow. Plenty of room on the C10 chassis for more length.
I'm using band clamps at the collector to the exhaust pipe.
Old Jul 29, 2018 | 12:02 PM
  #37
SLWRDE's Avatar
Veteran: Navy
As anyone used the Speed Engineering headers with the Hooker forward bias engine mounts Part# 71221008HKR on an early GM A body and if so did you run into any problems? I have a 65 Cutlass 6.0L and 4L80 that I am trying to find some headers for. I really like the Hooker headers but if I can use these Speed Engineering headers with the engine mounts I got and save some money then that would be nice. Thanks for all of the help
Old Aug 25, 2018 | 10:27 PM
  #38
GimmeLSx's Avatar
How low do they hang relative to the cross member? Is 1" off the firewall the max you can go before the headers start to run into fitment issues?
Old Aug 26, 2018 | 02:49 PM
  #39
chuckd71's Avatar
Thanks
Jarhead
They do a bit, yes, probably more than I would like given how low my car is (but I plan to raise the front an inch or so). When I go get the car to bring it to FL for a while I'll take some pics, but for now there are some in this thread if you scroll down a bit. https://ls1tech.com/forums/conversio...rtible-35.html
Not sure how similar the earlier years are, but I used the rear biased mounts and there is no way they would have fit my 71 if I had used the forward mount. Looking at the room I have in front and behind the motor I'm not really sure why I would ever use the forward mounts anyway.
Yeah, probably so. They get really close to hitting things if you go forward very much at all. At least mine do. The Holley rear-bias mounts are actually a tad more forward than I had my Dirty Dingo mounts (which might be worth considering if you want to run these headers).
Old Aug 26, 2018 | 03:19 PM
  #40
SLWRDE's Avatar
Veteran: Navy
Chuck,
Thanks for the info. The reason I went with the forward bias mounts is because I am using a 4L80 trans with my 6.0L and Holley's instructions say that I wouldn't have to do much/if any mods to the trans tunnel.
The price for these headers can't be beat but if they won't work on my setup I guess I will have to purchase the Holley headers.
