6.0 And 6 speed into a 98 silverado questions
I got a silverado for 700$ its a 2500 longbed i was thinking about tossing in an 5.7 it originally had a 454 vortec but the guy ran it too low on oil and burned it and the trans fluid is black its a 4l80 could prolly be serviced and fixed but what if i just go with a 6l80 6 speed and a 6.0 is it hard to do? And where the heck do you get wiring harnesses and engine mounts
Whats your plan for the truck? If you're looking at towing, I would go back with a 454. As far as engine swaps go, the LSx platform is probably the easiest to work with, but you're still going to run into issues. Namely engine mounts, driveshaft, exhaust, and wiring.
Ill probably do some towing with it but not alot mainly my daily driver/hunting rig What if i just use a 4l80E with it? Or could i use my old 4l80 thats in it if i serviced it where would i get a wiring harness and engine mounts etc? its a 98 2500 longbed
