GM 2007-current Vortec gas pedal pinout
Hi guys,
I have a holley EFI Dominator ECU and its harness for a 58x DBW engine, Holley calls for a passenger dbw pedal (10379038 ) while I got the truck pedal (ACC-1007 )already mounted under the dash, they both are 6 wire pedals and I believe they can be interchanged if I swapped few wire connections, I searched all over the place to find a pinout for both but couldn't find any useful info, I would be grateful if anyone can pass any good info for me regarding the pinouts for both pedals. Thanks,,
ACC-1007 doesn't cross over to anything I can find if you tell me what year it is out of I can get a pin-out on it and it's ECU if needed.
10379038 - CADILLAC CTS 2004-2015
A APP 2 Low Reference E38 X102 Pin 7 E67 C1-37
B APP 2 Signal E38 X102 Pin 5 E67 C1-49
C APP 2 5 Volt E38 X102 Pin 6 E67 C1-35
D APP 1 Low Reference E38 X102 Pin 4 E67 C1-36
E APP 1 Signal E38 X102 Pin 2 E67 C1-47
F APP 1 5 Volt E38 X102 E67 C1-33
MFG Year Model Chassis Transmission Engine Operating System Stream
Cadillac 2004 CTS-V Sedan Manual 5.7L (LS6) 12588804 (PCM) LS1B
Cadillac 2005 CTS-V Sedan Manual 5.7L (LS6) 12592618 (PCM) LS1B
Cadillac 2006 CTS-V Sedan Manual 6.0L (LS2) 12605669 (ECM) E67
Cadillac 2007 CTS-V Sedan Manual 6.0L (LS2) 12609051 (ECM) E67
Cadillac 2009 CTS-V Sedan Automatic 6.2L (LSA) 24249179 (TCM) T43
Cadillac 2009 CTS-V Sedan Automatic 6.2L (LSA) 12632176 (ECM) E67
Cadillac 2011 CTS-V Coupe Automatic 6.2L (LSA) 24256125 (TCM) T43
Cadillac 2011 CTS-V Coupe Automatic 6.2L (LSA) 12639469 (ECM) E67
Cadillac 2012 CTS-V Sedan Automatic 6.2L (LSA) 24261871 (TCM) T43
Cadillac 2012 CTS-V Sedan Automatic 6.2L (LSA) 12653238 (ECM) E67
Cadillac 2012 CTS-V Coupe Manual 6.2L (LSA) 12635457 (ECM) E67
gixxer92, I made a mistake, the pedal I have is from a TBSS, not a vortec truck, it has 6 pin and a similar plug to the corvette c6 pedal, will they interchange?
The pin out is the same for the CTS and the Trailblazer.
I looked at the 07-08 Trailblazer AC Delco part number and it is the same. I have one at home along with a Corvette pedal. I want to check the resistance (sweep) 0-100% and see if it is the same between the pedals.
Andrew
