Converter flexplate woes
Old Mar 3, 2016 | 06:43 PM
OmenNova's Avatar
Default Converter flexplate woes
Guys I've hit a snag and I need help. Bolting my LS3 to a Th350. I have the Advanced Adapters dished flex plate and spacer for the snout of the stall. It didn't fit right so we slid the trans back. The stall still has a gap between the mounting ears and flexplate even when it's bottomed out into the crank adapter. It seems like when it's bottomed out in trans and then slide towards the motor it only moves a VERY small amount not enough to be the expected 3/16. The gap between the converter and plate is 3/16. In theory I should need the spacer, but should I try to remove it and see how it fits without?
Not sure the best way to approach figuring this out. Also it's a summit racing stall and the pilot of it is flat/machined if that helps any.
Old Mar 3, 2016 | 08:30 PM
S10xGN's Avatar
The crank adapter is there to keep the converter snout centered and running true. Leave it out and there'll be big trouble...
Old Mar 3, 2016 | 09:11 PM
OmenNova's Avatar
I know that's why it should be there but with it there, the converter can't even slide out of the trans any and the flex plate doesn't meet up with the TC tabs. I figured if I took it out and slide it the proper amount that it may meet the factory crank. The way my converter snout is I don't believe any/enough material could be machined off of it.
