AJE K-member SN95
I read a lot of people running AJE k-member but using UPR LCAs or UPR Coil over/shock kit; why is this?
I was thinking about doing just the k-member only with their spring perches to use the stock suspension setup but then decided that I should probably upgrade to tubular control arms. Just trying to figure out what works with the AJE K and not having to modify absolutely every piece.
Thank you for your advice/feedback!
