Which DBW TB for LS6 Intake Conversion
My questions are:
1) What DBW TB do I need to purchase? I am not worried about bracket clearance as I took off the truck accessory brackets.
2) What plumbing/hose modifications are needed? I'm aware of the injector clip difference and will either re-wire or use an adapter.
3) Is a water pump change required for this to work? It seems the truck water pump is tall.
Is there anything else I need to know about? Currently it's just headers, intake and a mild tune. Plans later will include cam and head work.
Thanks
Also does the size of the actual alternator or mounting points change on it? Do I need to swap to the Camaro alternator to run that bracket setup?
Later when I add power steering and AC, do I run the truck components or look for Camaro ones?
Thanks
Keep the TB and truck accessories, remove the idler boss on the alt/ps bracket. Clearance the WP you have, or use an ls3 2010 camaro WP. Although he earlier TBs wont allow for clearancing the WP casting, so the 2010 WP will be needed. Cant tell which from your pic. The 98-02 Camaro WP with 3/4" spacers will work too.
Search "LS Idler pulley relocation"
