flywheel question
Old Mar 26, 2016 | 10:21 PM
monte0's Avatar
Default flywheel question
The flywheel on my motor was originally mated to a 6l90E it came with (three bolt flywheel). The new trans I got is a 08 4L80E and it has a 6 bolt converter. Should I stick with the six bolt converter or get the matching flywheel?
I do plan on changing to a aftermarket higher stall convert later on but might be a couple years. Are the aftermarkets 3 bolt or 6?
Attached Thumbnails flywheel question-wp_20160326_16_27_41_pro.jpg   flywheel question-wp_20160326_16_28_08_pro.jpg
Old Mar 27, 2016 | 01:52 PM
truckdoug's Avatar
They are available in either 3 or 6. I have done 3 bolts in a 6 bolt converter. It made some racket so I drilled it for the other 3.
Old Mar 27, 2016 | 07:46 PM
monte0's Avatar
I was thinking of drilling the other three but was worried the flywheel offset was different so didn't try it.
Old Mar 27, 2016 | 10:33 PM
truckdoug's Avatar
yeah you have to egg them a fair bit. all the "LS" converters (stock 4l60e,6l90 etc) have a 11.066" bolt circle diameter while the 4l80e has a "gen 2" converter stock and uses an 11.5" bcd. so it ends up being like .200" you have to remove. it's not much in my book considering it centers on the snout anyways.
Old Mar 28, 2016 | 09:02 PM
monte0's Avatar
Thanks for the info, I'm going to just get a new flywheel just have to figure out which one. Man did they change **** a lot over the years, lol
Old Mar 28, 2016 | 11:08 PM
truckdoug's Avatar
yeah they mixed and matched a bit. just get a stock 4l80e flexplate, spacer and bolt kit.
