Stiffening up throttle body spring?
Old Apr 5, 2016 | 05:39 PM
romancommander's Avatar
Default Stiffening up throttle body spring?
Hey guys, just finished getting my LS Swapped Nova running. The throttle pedal hooks to the LS1 throttle Body and the only spring is the throttle body spring. It feels a little light, do they make a stiffer throttle body spring? Or do you have to add a secondary one?
thanks
Old May 18, 2017 | 10:41 PM
TxFireman1972's Avatar
I know this is an old post, but curious if you ever found anything,
Old May 18, 2017 | 11:24 PM
SweetNova's Avatar
TxFireman1972,
There's a few different TB springs any they're color coded:
Color-coded springs used on GM throttle bodies are: blue (?), brown (early F-bodies), and orange (trucks). The brown spring is the softest one, followed by blue, the orange spring is the stiffest, and was used on trucks.
This info is what I've came across...
Old May 18, 2017 | 11:52 PM
Originally Posted by SweetNova
TxFireman1972,
Good info, thanks. Any idea if you can buy just springs anywhere? Mine appears to have no color lol.
Old May 19, 2017 | 05:33 AM
fst100's Avatar
subscribed lol
Old May 19, 2017 | 04:09 PM
imma_stocker's Avatar
These throttles aren't meant to swap springs. Never heard of the color coding either.
Option 1, grab your good pliers and coil the spring around tighter. Gloves highly recommended in case it slips off and catches you.
Option 2, buy/swap a newer throttle body.
Old May 21, 2017 | 05:43 AM
stevieturbo's Avatar
Adapt and overcome.
Of course springs can be added....it's up to you to figure out how.
It will probably involve adding some metal the the existing cam to affix a spring too, and finding somewhere on the engine to attach the other end, but it is most certainly doable.
BBK LS intake albeit with a Ford TB ( I'd used it with the carb intake/elbow previously, but had to do a similar spring fitment )
My cable pulls this blade from the underside of the cam, can't find any pics of it fitted and I recently changed to DBW anyway
I had to weld both a different cam to the throttle spindle, then add the piece to attach the springs to. They're just the typical Moroso or similar throttle return springs, cut and shortened slightly.
You could also add a spring to the pedal, but it would be much safer to do it all at the throttle blade itself.
