4L80E connector wiring question
Thanks,
Phil
I have a 98(I think) that has the connectors still attached< I will look at to see if there is a color mis-match, probably be tomorrow though.
pin 79 should be my 3-2 shift solenoid
Thats a 60e wiring diagram. The 80e only has a 1-2, 2-3, and TCC solenoid. The 60e has 4 solenoids instead of the 80e`s 3 solenoids.
I think pin 75 and pin E on the connector just get 12v on start and run, they don't necessarily go to each other. I went through this same experience when I got my lq4. I bought a connector and had to use a multimeter, a truck wiring pinout, and a trans pinout to figure out all the wiring due to color fade and some ambiguous coloring. This one helped me http://www.rostratransmission.com/ma...Form4176E.pdf.
Just be patient and use the process of elimination!
I think the 4l80e has two speed sensors. 99-02 red connector 20+21, 22+23. I think ones Iss and maybe ones Oss? Someone else can correct me but a search could probably tell you which one to tap.
