Engine is In!
Dropped the new motor in, found a good spot for the ecm behind the left headlight area alot of room there and can still mount the washer bottle in the stock location. Modified the a/c mounting bracket so I can use the original compressor. Ordered up a smaller diameter P/S pulley from Dirty Dingo. Now I need to run my new fuel lines, went with plastic lines so I need to route them carefully. I was on over achiever this weekend!
