LS3/TR6060 into 91 C1500
Check this out, you could run a one piece slip yoke drive shaft with this. This and the Core-shifter and be done with it.
I appreciate all the help guys, keep going backwards but I ain't giving up.
Rock
http://67-72chevytrucks.com/vboard/s...d.php?t=499225
. Those sure looks like exactly what I need. Just one question if you don't mind, any reason you went with the 4 different brands for the fittings? I see Russell has 640820 and 640830 that look like the sizes and attachments and I have all either Russell or Summit Racing AN fittings for everything else so I'll probably stick with them.Thanks again,
Rock
Rock
Rock
You can see the 3 2x6 and 2x8 I had to put under the tires to be able to get the hoist under the control arms
Next question, just to verify, the stock v6 mounts had 5 and 6 bolts, the 4 holes in a rectangle in the pic on the left and 1 or 2 on the side of the frame, looks like the v8 mounts I picked up just use the 3 bolts in the pic on the right, that look correct? Not sure how the hell to get the nuts up to the top holes, gonna be fun making that work.
Thanks,
Rock
I have a tip that you may or may not want to look into,I have similar clamshell mounts for my S10 and they have a pretty large void on either side and it leaves the mounts with a mushy feeling for the power I intend to put down. Supposedly you can fill that void with polyurethane it will remove the play in them and make them more solid feeling/stronger but still flexible, It also works on some transmission mounts.
I also got the fuel pump swapped out and -6 AN fittings and stainless braided hose up to the fuel filter/regulator. Those Russell fittings 640820 and 64083 were exactly what was needed to connect to the feed and return lines on the fuel pump and connect to the AN fittings. Dropping the tank was a huge pain since I hadn't really planned to put the truck up when I did so I hadn't run the tank down, that bitch was heavy. I had started to pull the bed but since I backed it into the garage I abandoned that plan, but only after I broke one of the bed bolts.
This is what I say to that ****** bolt
Also ended up bending the **** out of the rusted to **** straps holding the tank so I replaced those was well.
Started working on mounting the radiator, gonna be close but we'll see how it goes.
I really appreciate all the help and quick responses from everyone, I'll keep updating as I check things off the list or hit the next road block.
Rock
Rock
For the radiator I'm trying to fit the Camaro one because the tranny has cooler lines and I measured one in a guy at work's car that has a similar year and it seemed close. Now that I've started I think it's a bit taller with the high filler neck.
Rock
I would say header clearance was most critical in my case.
I did get the front core support notched to fit the radiator, need to drop down quite a bit. Figured now is good time to learn to weld so I picked up a Harbor Freight welder and played with that today. Gonna just drop the lip where the radiator mounts down about an inch or so and that'll give me the clearance I need. Just need to practice a bit before I feel comfortable doing it.
Thanks again for the help guys, still feel good with the progress I've made this week.
Rock
Thanks,
Rock
