LS3/TR6060 into 91 C1500
And here's the motor/trans that's going in.
I expect to have plenty of questions even though I've got half a garage full of parts already. First engine swap but not new to working on the truck, just about everything you see, other than paint, I've done myself. I'll post up a parts list and the plan shortly but wanted to get a thread started.
Rock
First question for everyone. I'm trying to install the Holley AC relocation bracket and it seems like you have to at least loosen the water pump. Anyone have a trick to get the lower socket cap bolt in without pulling the water pump?
Rock
Some of the goodies that I've got stockpiled so far.
Schoenfield headers (ceramic coated)
BP automotive fuse block
-6AN fittings and stainless braided line, HFP in tank pump with corvette filter/regulator.
Holley oil pan, went with the 302-1
Camaro radiator and electric fans (measured and it'll be close but I'm hoping these work)
Rock
Thinking I may have to grind the short shaft flat and drill holes that match the Hurst shaft's 2 bolts but I think this would weaken it, anyone done something similar or have any suggestions? The **** is just a friction fit on the end, no mechanical way it's fastened on the end.
Thanks,
Rock
http://core-shifters.com/collections...eed-trans-swap
What are doing for the drive shaft since it's setup of an IRS? If you have trouble with it you can always have one made at The Drive Shaft Shop.
I'm doing an S10 with a LSA supercharged 6.0 and TR6060 and have the driveshaft figured out but need to start working on the clutch master cylinder to trans adaption.
For the driveshaft I found a company local that when I contacted them to see what they could do for me the guy didn't even hesitate before he came up with a plan. He did talk it through, I think mostly to himself, but he knew exactly what I needed and said they could do it with a 24 hour turnaround.
Rock
Check this out, you could run a one piece slip yoke drive shaft with this. This and the Core-shifter and be done with it.
As for the shifter that unit you pictured moves the shifter way back. You may not need that. When you mock up the engine see where the trans sits and whether you can use a standard shifter like showdog posted.
I welded a dog leg onto the shifter in my TKO. Pretty easy to do and gives you probably 4-5 inches of offset in the shifter location in any direction. There are a number companies that make offset shifters but easy to modify a standard one.
I checked that link to that output shaft kit and noticed that it only fits up to 2010. Also noticed that it includes that shifter relocation item too but maybe you wont need that. I will keep watching....
Are you still in the Air Force? I have been retired for 24 years, just sold my business last week! Plan to move to Ocala FL in the next 6 months or so! Play with my toys!
Al
Al
Still in the AF, 23 years and counting, thinking of making a career of it
Rock
I was hoping not to spend more money on the shifter but I'll see when I get the motor mocked up in there.
The fuel lines along the frame look fine so I wasn't expecting the rust, ordered a new one from Rockauto (gotta love the name ) so hopefully I'll get that in and some work done this weekend on that. Oh and I snapped one of the bed bolts when I was pulling those
Rock
