Clutch master cylinder help!
Old Apr 19, 2016 | 09:42 PM
nlpy8b's Avatar
Exclamation Clutch master cylinder help!
My problem is I am swapping out all of my T56 clutch and hydraulics, and my existing adjustable master cylinder does not appear to be compatible with my stock replacement master cylinder.
I believe my existing master cylinder maybe an old Mcleod unit with a aluminum body and a banjo bolt style connection. My new stock replacement master cylinder appears to have a push and lock style connector with a pin. Is there a way to use my existing line to connect to the stock style master cylinder?
Old Apr 19, 2016 | 09:44 PM
nlpy8b's Avatar
Is there a fitting with a stock style pin retained connector on one side and a banjo style on the other?
Old Apr 20, 2016 | 05:26 AM
1981TA's Avatar
Got pictures?
Old Apr 20, 2016 | 07:55 AM
1964SS's Avatar
I've never seen an adapter like that. You might have to buy a stock push on hydraulic line.
Old Apr 20, 2016 | 12:18 PM
1981TA's Avatar
...or have an existing line modified, like I did. The local Car Quest got me taken care of for about 20 bucks.
