LS swap in rock bouncer
Info on setup
5.3l motor {slight work done}
turbo350 trans{work done to trans}
Toyota transfer case
Toyota 8in axles 5.29 gears
37in tires
weight of rig should be around 2500lbs 2800lbs
What I want to know
Looking at getting a lm7 out of a 01 suv comes with wiring and pcm
going to have the wiring cut down and pcm tuned for it. That mean only using 2 o2 sensors not emissions stuff like that. I was wanting to do th easy upgrades to it longtube headers good intake what do I need to do to remove the emissions stuff also will a turbo350 mount to the engine like a older 350.
Info on setup
37in tires
What I want to know
http://www.ebay.com/itm/LS1-EGR-Smog...BWlDj2&vxp=mtr
http://www.ebay.com/itm/LS-EVAP-PURG...ZXDzux&vxp=mtr
Then when the ECU is tuned, you can modify tune for non-emissions etc.
Transmission will mount up, just minus 1 bolt. You will need a cheap hub adapter that bolts on top of the flexplate to center the converter snout.
