Clicky injector
Old May 9, 2016 | 11:55 PM
jeremytap's Avatar
Default Clicky injector
First things first. This swap is a 2004 tahoe 4.8l into a volvo 240. We used the stock harness (I did the wiring) and it seems to run fine.
But now I'm running into a strange problem, if we start the car and then shut it off, then turn it back on but don't start it, the number 3 injector just starts clicking away. Probably clicks every 1/2 second or so. And I know is the injector because if I unplug it the clicking stops. I have tried 2 other pcm's with the same result.
I don't know of any codes yet, I didn't have hp tuners with me when I went to work on it. So what could be going on with it?
Thanks in advance
Jeremy
Old May 10, 2016 | 06:56 AM
svslow's Avatar
You are positive it is just the one injector? I would go through the wiring and make sure its not getting grounded some where before the ecu. Also, verify the resistance of all the injectors.
Old May 10, 2016 | 08:06 AM
jeremytap's Avatar
Yes, it's just that one injector. Unplug it and the clicking stops, same with 2 other pcm's and a couple different injectors.
Old May 10, 2016 | 08:42 AM
Pop N Wood's Avatar
Why are you worried about this?
Just turn the key off and be done with it.
Old May 10, 2016 | 09:13 AM
ls1nova71's Avatar
Never seen or heard of one doing that, but I would suspect that if it is indeed pulsing, it could fill the cylinder with fuel and hydrolock the engine, I had a leaking injector do that once, was a bad deal.
Old May 10, 2016 | 10:07 AM
Blue89Bird's Avatar
clean it? Plenty of videos online showing how, just jump 12v and shoot some wd40 in it and see if it changes any.
Old May 10, 2016 | 11:08 AM
jeremytap's Avatar
It is shooting fuel when it does this, I have a gage on the rail and it goes down with each click.
I don't think it's a dirty injector either since we tried a couple different injectors with the same result.
Old May 10, 2016 | 06:07 PM
jeremytap's Avatar
https://youtu.be/D2sX14caEzA
Here is a video on what it's doing.
