lq9 pilot bearing
https://ls1tech.com/forums/manual-tr...-can-here.html
12557583 Pilot Bearing (not shown) Use with manual transmissions if the input shaft extends beyond the bell housing 5mm or less (or recessed slightly)
The previous owner used the smaller type bearing. Would this setup even work if it was wrong? Im confused as to what is going on here. I have been trying to fix all the hack work that was done on the truck when i got it.
The smaller bearing would work for a few miles, but the input shaft would be unsupported, and it would eventually tear up the input from the undue stress.
The guidance by the GMPP manual above is your best bet. However, you'll note that there isn't anything about what to use if the input extends between 5 and 20mm (~.200 - .750") beyond the bellhousing because GM didn't offer a trans input in that length. People have successfully spaced the small bearing aft in order to ensure proper engagement of the input shaft snout. If the large bearing doesn't work, you could use spacers to space the small bearing out of the bore up to just under half its width.
