V12 LS1 - First fire up and challenges
Put a vacuum pump on this thing, that should help a lot. Lots of oil being thrown around in there, too, so maybe crank scraper(s) would help too. Crankcase ventilation and water circulation will both be important to stay on top of. Care to share what the mild cam specs came out to be?
The cam in this one is 228 / 238 with 0.589 lift
Stock 5.7 LS1 stoke, rods, porting, valves and pistons.
Thanks for the vote, much appreciated.
Or don't, it's your choice. More importantly, it's your money. This is a very awesome project no matter what. The 4.00" bore on your next V12 does open up a lot of possibilities for heads. Even splicing two sets of LS3 heads together with the hollow stem intake valves is a really good idea for your 9L.
Definitely get the vacuum pump, as that should help a lot. Might want to talk to the folks over at Improved Racing about a crank scraper.
From the perspective of a flat plane crank v8 being like two inline 4s, what we have here is 2 straight 6s. So the same principle applies, except we need a 3 plane crank. That is because a 4 stroke engine with flat plane crank has 4 possible firing positions per bank, and with 6 cylinders on each bank that would mean firing some at the same time in a V12.
Also a flat plane V12 would give up the benefit of neutral primary and secondary balance (The reason I6 and V12s are so smooth). Yes this engine actually balances better than even a cross plane V8 LS!
And for some good news... Our next project is going to be testing some flat plane crank ideas in the V8 LS. It has been done before, and we have some ideas to minimize impact of the the secondary imbalance that is inherent with a flat plane V8. Why should the Ford and Ferrari guys have all the fun!
You're doing great. Looks like you are exploring different uses for your creation. That will be a big asset when it hits the market.
I wish I could say I'll get one but alas, I'm just a penniless pensioner.
Ken
We are not overly concerned with tuned length headers for this car, it is a cruiser and show vehicle and this particular engine already made more than the Camaro will be able to to to the ground. We actually hope it does not make too much over the 717hp with the ITBs and big exhaust as we are fast approaching the limits of the trans, cooling and fuel system.
All that said, there is a more powerful LS12 build in the works to really push the limits of the stock donor block construction. We expect tuned length headers to make more of a difference on that one.
Keep up the awesome work! My dream LS is a 420-500~ cube NA build but I guess this can be the new dream build when I get there...
'MURICA!
P.s. those ITBs and headers... deeeelicious.
