V12 LS1 - First fire up and challenges
Old 09-30-2016, 10:13 AM
  #41
1CAMWNDR's Avatar
That is just too damn cool.
A 4" bore with 2.75" stroke would still be 414 cubic inches and MIGHT lower and shift the torque production up higher in the rpm to save the driveline.
Old 10-14-2016, 02:59 PM
  #42
V12LS's Avatar
Thanks everyone, there is still a lot to do on this car and SEMA is just a few weeks away! Injectors and fuel pressure regulator just arrived, the engine is painted and the car is partially painted. Is anyone here heading to SEMA?
I think we should be fine, ATI built the toughest possible TH400 that is still full auto specially for this project. We can't wait to actually drive one of the V12 engines on the street!
I'll try and get some update pics posted.
Old 10-18-2016, 05:51 AM
  #43
Sparkie's Avatar
I had this idea to build a V12 from 2 SBC blocks 10 years ago. But after hearing "It will never work" from everyone I talked to, I finally gave up the idea. Now it's great to see that my idea wasn't so crazy after all. I am planning to go forward with my idea but with the LS rather than the SBC So I'm hoping I can learn everything I can from someone who has already done it.
Old 10-21-2016, 11:18 AM
  #44
Jimbo1367's Avatar
Great job. Best of luck !!!!!
Old 01-07-2017, 03:52 AM
  #45
Sparkie's Avatar
I came up with the idea that I wanted to try to cut and weld 2 SBC V8s to make a SBC V12 about 10 years ago. At the time, I was not aware of anyone attempting such a thing. Now that I see this procedure has been successfully done several times with the LS block, I have renewed interest in doing this myself.
From what I understand, all of the LS V12s were made starting with 2 aluminum blocks. So my question is: Has anyone tried making a v12 with the cast iron LQ blocks, which, from what I understand, are exactly the same as LS blocks only they are cast iron rather than aluminum.
Old 01-07-2017, 10:51 AM
  #46
Michael Yount's Avatar
Welding parts of two aluminum blocks together is do-able....not easy, but do-able. Welding together parts of two cast iron blocks is an entirely different matter.
Old 01-07-2017, 12:26 PM
  #47
1989GTA's Avatar
Maybe two SBC aluminum blocks would be a better starting point for what you want to do.
Any update on the LS V12 project?
Old 01-07-2017, 01:29 PM
  #48
Senna's Avatar
Cool project
I was involved in a similar project more that twenty years ago based on SBC.
We did similar prototype welding two blocks together, although we started with two as cast non machined blocks. welded heads together, billet crank and pinned two camshafts together.
It'll be interesting to see where this goes.
Troy
Old 01-07-2017, 02:04 PM
  #49
Azryael's Avatar
Wow, I think I know what I want to stuff into my MB now!
Old 02-13-2017, 09:59 PM
  #50
V12LS's Avatar
1989GTA
Going well thanks 1989GTA, as you have all mentioned the welding is quite challenging even with an alloy engine. We have now made four prototypes and are moving to our own casting. Plans are for alloy and iron and the iron block is even tougher than LSx, we can't wait to push the limits with the new blocks.
Also we will likely take the Camro on power tour.
V12 LS Camaro
Old 02-14-2017, 02:12 AM
  #51
S2KIWI's Avatar
So awestruck by what you have achieved and glad to see progress continues and you're getting the attention you deserved.
Curious also as to if friction welding could be done on a large enough scale and accurately enough to achieve this also?
P.s. If I didn't know any better, I'd say that picture looks totally photoshopped. It's mind bending to see an LS transformed into a V12!
Keep it up. I'd love to shoehorn one of these into something terribly unsuitable.
Old 02-14-2017, 05:54 AM
  #52
8.Lug's Avatar
You should probably google the definition of friction first.
Old 02-14-2017, 11:24 AM
  #53
Jimbo1367's Avatar
Do some good head now. Up the compression and toss in a real cam. Then some boost. Turn it up!!!
Old 07-19-2017, 10:23 AM
  #54
V12LS's Avatar
The first all alloy one piece casting V12 LS has hatched.
V12 LS Block http://woobox.com/x895b7/gallery/pLcrEoL3cCE
Old 07-19-2017, 11:10 AM
  #55
1989GTA's Avatar
Oh my. Looks very promising.
Old 07-19-2017, 09:03 PM
  #56
Hank Peabody's Avatar
Wow that is amazing!! I cant wait to see where this goes, I need one!
Old 07-19-2017, 11:42 PM
  #57
slocaddy's Avatar
Bet I could fit one under sinister hood......
Old 07-20-2017, 05:59 AM
  #58
omegatotal's Avatar
IMG SNIP
OOOHHH YESSS!
Old 08-25-2017, 02:14 AM
  #59
V12LS's Avatar
And now the iron block V12 LS is here!
V12 LS Iron block
Old 08-25-2017, 10:55 AM
  #60
aggie91's Avatar
Did the Camaro make in on Power Tour?
Quick Reply: V12 LS1 - First fire up and challenges
