E67 TB and pedal compatibilty
Old Jul 16, 2016 | 09:58 PM
csouth's Avatar
Default E67 TB and pedal compatibilty
So I'm trying to simplify my tuning situation as much as possible. I have an e67 TB and ECM from the same 07 TBSS motor. I am getting an error with the current uknown flash and Monte SS pedal even when repinned. One I know because its looking for a TCU that does not exist and the other is a p2138 TPS. With the pinout being the, shouldn't the CTS-v pedal work with the TBSS DBW TB ? I'm thinking this would allow me to flash the ECM as an '07 CTS-v since it had e67 and manual trans. Thoughts anyone?
Old Jul 17, 2016 | 12:02 PM
Project GatTagO's Avatar
Chris,
I am as suing that you are using the Impala SS pedal....this?
http://www.rockauto.com/en/moreinfo....440301&jsn=514
I am surprised that you are having issues...
Andrew
Old Jul 17, 2016 | 12:34 PM
csouth's Avatar
Andrew,
I'm actually using the Monte SS pedal. I see the part numbers are different between the Monte and Impala. Didn't you use to the Monte on your GTO and Impala on the cougar?
I'm not sure what base tune is on my ECM now and haven't gotten a clear response from the person that tuned it when asked. The ECM is still looking for the TCU and running in limp while giving me 0101 and 2138 for the pedal. I figured if I bought HP tuners I'd be good because I could lay down the CTS-v tune from 6spd e67 car. The cts-v pedal wires the same as tbss where the motor, ECM and tb originated....
Old Jul 17, 2016 | 04:00 PM
branndonw's Avatar
The LS2 CTSV pedal will not work with the TBSS OS.
Each pedal has 2 APP sensors in it. Not all sensors sweep the same even though they may have the same pinout.
On some pedals, both sensors sweep 0v to 5v, on some, both sensors sweep 5v to 0v, on some, sensor 1 may sweep 0v to 5v while sensor 2 sweeps 5v to 0v, and on some, sensor 1 sweeps 5v to 0v while sensor 2 sweeps 0v to 5v.
I do have a brand new ls2 ctsv pedal that I dont need if you want to run the ctsv OS.
Old Jul 17, 2016 | 04:15 PM
csouth's Avatar
On some pedals, both sensors sweep 0v to 5v, on some, both sensors sweep 5v to 0v, on some, sensor 1 may sweep 0v to 5v while the sensor 2 sweeps 5v to 0v, and on some, sensor 1 sweeps 5v to 0v while sensor 2 sweeps 0v to 5v.
Thanks for the reply and the insight. What you've stated is probably the precise reason the Monte Pedal won't work even after changing the pins. I did get a hold of a CTS-V pedal from a friend of a friend. My intention would be to try the CTS-V OS since it was an E67 6spd car. What OS are you using since you did the 6pd in your TBSS?
Chris
Old Jul 17, 2016 | 04:17 PM
branndonw's Avatar
I switched to an E40.
Old Jul 17, 2016 | 04:28 PM
csouth's Avatar
Ah! Thats why you went to the Lingenfelter converter box. Just checked your swap thread, nice work....
Old Jul 17, 2016 | 04:51 PM
branndonw's Avatar
Thanks!
Old Jul 17, 2016 | 06:44 PM
Chris,
I don't believe that Chevy ever made a Monte SS. It is entirely possible that in a previous post I said Monte instead of Impala. The pedal I posted earlier is what I am using in my GTO. The GTO has a e67 that came with the GMPP harness kit. The pedal included in the kit was a CTSV pedal and swapping to the Impala SS was not a problem at all. In fact, I always thought that all Gen IV pedals are interchangeable with the exception of GTO and TBSS pedals, which seem to be slightly off...I may be wrong on this, so I am open to be schooled with better knowledge.
Andrew
Old Jul 17, 2016 | 10:40 PM
EFIHARNESS's Avatar
Just to add more to the mix, most of the sweeps in the pots can be changed by reversing
5v and low ref. Steve
Old Jul 17, 2016 | 11:57 PM
gofastwclass's Avatar
Chris,
I respectfully beg to differ sir... https://en.wikipedia.org/wiki/Chevro..._.282005-07.29
The 2006-2007 cars come with an aluminum front wheel drive LS4 5.3.
Too bad the crank and bellhousing bolt pattern are front wheel drive specific.
Old Jul 18, 2016 | 09:21 AM
Fair enough. I just looked up the pedal and it's the same as the Impala SS pedal.
Andrew
Old Jul 18, 2016 | 10:44 AM
csouth's Avatar
Andrew
Yeah, I'm not quite sure here. I think lot of it has to do with the tune that is on the controller. Although the pin is correct between the pedal and the harness, I think the OS is looking for a different reading based on the vehicle tune that is on the ECM. When I asked what tune was on the ECM, I never got a direct answer. The response was "the computer doesn't care, you must have something wired wrong or the pedal is bad.." Well all I know is I did have it wired as TBSS when I bought the harness, so i received a p2138. I repinned it to the Monte pedal and cleared the code. Tried several restarts after I cleared it and the code did not return. The p2138 did not come back until I sent the ECM back to have it checked for VATS. I'm also getting a 0101 for lost comm with TCU which wasn't there before.
I've just come to the conclusion I need to be able to actually see whats on this ECM instead of relying on someone else to tell me. At least i can be more informative if I need to ask for assistance. I plan on installing a cam at some point so I won't be married to some mail order tuner either.
I definitely appreciate all the responses from you guys...
Old Jul 18, 2016 | 12:12 PM
Andrew, it makes sense they share the same pedal. They share the same engine and transmission from the GM parts bin as well as chassis.
CSouth, I can tell you from experience swapping several GM engines and controllers into non-stock applications, it's ALL about the calibration and hardware coordination. Several of the pins are shared functions and the calibration is either looking for input or sending outputs differently based on the calibration loaded.
Without much effort I can think of several examples. Given a bit of time several of us could probably come up with more examples of this than we have space for on this forum. Fortunately the people at HP Tuners are absolutely amazing at giving us access to make changes to many (but not all) of these parameters.
Old Jul 18, 2016 | 12:27 PM
csouth's Avatar
You're response and my conversation with someone else has added confidence to my thought process. It would only seem logical that the OS tune has to match the feedback its expecting on a given sensor. I'm curious to know what vehicle flash is on the computer? For me, I have but one choice , CTS-V as its the only 6.0 E67 manual trans I could find. I hear this is how the GMPP computers come so we shall see....
Old Jul 18, 2016 | 12:42 PM
I wish you well on your swap.
All the Gen IV controllers use external TCM's (Transmission Control Modules) so they are perfect for transmission swaps with a bit of rewiring. The calibration doesn't need to be changed much so you don't HAVE to use an E67 - unless that fits the pedal and throttle body you already own.
Right now I'm trying to piece together elements to go Gen IV drive by wire on a Gen III engine using mostly parts I have lying about from other swaps. I have a few options, but I don't have enough of anything to make a complete setup without buying something. I'm fine with that, I just need to be smart as I only wish to buy things once.
Old Jul 18, 2016 | 01:12 PM
csouth's Avatar
I've been able to by most of the parts for my swap once. Should I ever do another swap, I'm sure it would be easier with the knowledge I'm gaining from this one.
Yeah, the motor, ECM and TB were altogether from the TBSS. The only part I didn't have was the pedal. The previous owner was going to convert to carb so he didn't have it.
Having to buy a new pedal is not so bad, the old one is already sold and shipped, the replacement was picked up and I should have it tomorrow.
Old Jul 18, 2016 | 01:53 PM
TipsyMcStagger's Avatar
Don't mean to derail the OP's thread bit which pedal are you using with the E40? What flash is on your E40 and is your cruise control still functional.
Tipsy
Old Jul 18, 2016 | 10:54 PM
lizeec's Avatar
Throwing in more confusion, I'm using a E40 PCM out of a 2006 GTO which is a Gen IV and has no external TCM, and it has a SSR tune and I am using a trailblazer pedal and have fully functional cruise control. This is on a 2006 GTO LS2 & T56 combo in my 1966 GTO.
My harness was built by Speartech.
Old Jul 19, 2016 | 09:24 PM
csouth's Avatar
Found that I have the TBSS tune on my ECM. I have a spare e67 from an '06 Malibu. Does anyone know if I should be able to do a "write entire" over this with an '06 CTS-V tune?
