Rock Buggy LQ9 - setup parameters - Bog/lull off idle
I have setup my (2004) LQ9 using the FAST EZ-LS, originally using most of the default settings in the setup wizard, but started to play a bit with the numbers to get it running better/stronger... Seems to pull hard through all the shifts and RPM range after I have a bit of movement and rpm built up. If I "punch" it from a stand still from idle, I seem to get a "bog" or lull until it climbs in rpm..... Its transplanted in a rock crawler/rock bouncer so that initial launch is key, and Im missing out...
Motor internals are stock, with headers/exhaust and a aftermarket cold air intake....
Some of the current values I have entered in are:
Fuel pressure : 58 psi
Injectors : 25lb
Timing idle : 22
All in timing : 32
All in timing rpm: 3000
AFR:
Idle - 13.1
Cruise- 14
WOT - 13
Just looking some some input on the numbers I have entered in??? Things to change or look for ???
Thanks!
Injectors : 25lb
Timing idle : 22
All in timing : 32
AFR:
Idle - 13.1
Cruise- 14
WOT - 13
Thanks!
