L92 on the manual transmission
I apologize for the use of an interpreter. I do not know much English.
I hope that you will understand me.
We put the engine to the Escalade 2007 L92, in the Ford Thunderbird. Manual Transmission.
For firmware using HP tyuners.
The program has established:
manual Transmission
"Cutoff RPM vs Gear" put speed limit for neutral 6000
Disables the TRC, as in the photo below.
Launch engine cutoff 6000. Turn-starts the engine cutoff 4200. Turn and start the engine cutoff 6000. And so through time.
When motion is felt low power. It seems to me that the problem TRC.
How to completely disable TRC?
What you need to do to the motor worked fine with a manual transmission?
