L92 on the manual transmission
Old Aug 1, 2016 | 02:34 AM
DooDllez's Avatar
Default L92 on the manual transmission
Hello!
I apologize for the use of an interpreter. I do not know much English.
I hope that you will understand me.
We put the engine to the Escalade 2007 L92, in the Ford Thunderbird. Manual Transmission.
For firmware using HP tyuners.
The program has established:
manual Transmission
"Cutoff RPM vs Gear" put speed limit for neutral 6000
Disables the TRC, as in the photo below.
Launch engine cutoff 6000. Turn-starts the engine cutoff 4200. Turn and start the engine cutoff 6000. And so through time.
When motion is felt low power.
How to completely disable TRC?
What you need to do to the motor worked fine with a manual transmission?
Old Aug 1, 2016 | 04:50 AM
DooDllez's Avatar
Old Aug 1, 2016 | 04:44 PM
Project GatTagO's Avatar
What ECU are you using?
Privet!
Andrew
Old Aug 2, 2016 | 09:33 AM
DooDllez's Avatar
12614085 YPLA
Delphi
*86YPLAK16356YESM*
Service. No. 12597121 6356
Old Aug 2, 2016 | 11:09 AM
LSX Power Tuning's Avatar
You may have to run a corvette manual tune to get it to work 100% correctly. That will require corvette TB, OS, and pedal though.
Old Aug 2, 2016 | 01:34 PM
DooDllez's Avatar
ECU firmware does not solve the problem?
The firmware also has a lot of settings for the manual. So it should work. Or I'm wrong?
