wiring question
Old Aug 18, 2016 | 10:05 PM
F100Rudy's Avatar
Default wiring question
Hi all,
I posted this in the new greeting section but I thought I'd put it here; I had a 2002 5.3 LS swap put into my 54 Ford F100 pick up. However, there is a battery drain 3.5 amps which I tracked to the external voltage regulator(on truck from previous 74 351m/400 motor)which the mechanic wired in to the harness. I suspect this should just have been excluded. I've been searching for a solution to this but I haven't been successful. Any help would be appreciated.
Thanks
Rudy
Old Aug 19, 2016 | 01:14 AM
Spaceboy1980's Avatar
How is it wired? My swap goes from the alternator to the battery. Your regulator should not be hooked up at all. A picture is worth two in the bush as the crow flies and all that.
Old Aug 19, 2016 | 07:16 AM
04Z06vette's Avatar
agree. if you are using the 5.3 alternator, you need to delete your old regulator and wire per the 5.3 diagrams.
Old Aug 19, 2016 | 08:14 AM
jcvett56's Avatar
^^ What they said. Your alternator should be wired just like the 5.3. The wires going to the computer from the 4-pin alternator plug. Then the large gauge wire(s) going to battery/starter. No need to utilize any of the original external regulator equipment that was original on the 54.
Old Sep 30, 2019 | 01:29 PM
ijimmy's Avatar
If you have an r44 alt , it will run as a one wire , without change , just hook up the charging stud to the battery , with the engine running it will put out around 14 volts , I have a couple vehicles running that way
