Updated valve cover w/ PCV
Thanks,
Brandon
In the day, the valve guide/seal test was, put in first gear, and with some one following in another car accelerate hard up to 5500 rpm or so, then abruptly let off the gas. As the car decelerates, have the person following look for blue oil smoke. High vacuum in the cylinder on deceleration pulls oil under the valve cover past worn seals/guides.
PCV pullover or an overactive lifter can cause oil to be pulled through the PCV system even at low vehicle mileage. A correctly functioning PCV system will only leave a film of oil in the intake manifold. Inspect the intake manifold to see if there is any oil puddling in the bottom. If there is you will need to replace the left valve cover. Two new left rocker arm covers have been released for trucks and vans. Technicians should replace the left rocker arm cover with GMP/N 12570427 for 2007-2008 or GMP/N 12642655 for 2009-2011. This rocker arm cover has a relocated PCV drain hole that prevents oil from entering the intake manifold.
Russ Kemp
This is GM's third attempt to mitigate the oil consumption issues plaguing LS1 engines and 1999-2013 LS engine trucks. For some reason the engine eats oil through the PCV setup and people who run catch cans catch a significant amount of oil. For millions of engines that don't it pools up in the intake. I was surprised when I pulled the intake manifold on my truck to see oil weeping out of the intake runner outlets.
New GM valve cover. Includes new gasket and grommets. Part number 12570427 for 2009-prior LS engines which has the hose connector barb for the PCV tubing. 12642655 is for 2010-2013 LS engines which uses a push on fitting connector.
