Corvette filter/regulator AN adapter question
Silver adapter between the regulator and the blue AN fitting. This is it pushed in.
This is it pulled out. Notice the difference in length. It also wiggles side to side a bit.
Anyone have these adapters? And is this correct?. There's really nothing I could do wrong- it just pushes in.
Had 3 leaks, I think one is fixed. (Between Fragola premade hose end and AN adapter at fuel rail).
- leak between premade Fragola hose end and AN adapter on output side of regulator
- leak between premade Fragola hose end and NPT to AN adapter at in-tank fuel pump.
I started out just snug tight. In my frustration I have probably overtightened them at this point. Using proper aluminum AN wrenches.
Andrew
