ls1 over heating
Old Aug 25, 2016 | 12:10 PM
  #41
Tanmanls1's Avatar
I just started it up and it reached 230 in about 5 mins, but I had my hood off and wasnt moving..
Old Aug 25, 2016 | 12:27 PM
  #42
s14hunter's Avatar
That new setup looks much better! Good job! Did you jack up the front of the car and run it?
The upper radiator hose routing up and above the radiator level is gonna be a problem.
Old Aug 25, 2016 | 12:30 PM
  #43
s14hunter's Avatar
You should really consider running the degas/surge tank setup I posted above.
Run a small tank back on the firewall behind the strut tower on the passenger side.
Like so:
Old Aug 25, 2016 | 01:23 PM
  #44
s14hunter's Avatar
Also, if it were my car, I would replace that 5.3 truck water pump with a 5th gen Camaro water pump. In an effort to keep the upper radiator hose as low as possible.
ACDelco 251-734 is the part number for the pump.
Old Aug 25, 2016 | 02:22 PM
  #45
joecar's Avatar
Originally Posted by Tanmanls1
Now do I still need to bleed out the steam ports? Also thank you guys for the help y'all are FREAKIN awesome
Yes..
Old Aug 25, 2016 | 03:55 PM
  #46
Tanmanls1's Avatar
Originally Posted by joecar
Yes..
ok thank you!
Old Aug 25, 2016 | 04:01 PM
  #47
Tanmanls1's Avatar
Thanks for the advice again! You've been a lot of help. I'm looking into getting the tank hopefully A local auto parts store has one!!!
Also, I jacked the car up and let it run until it got to about 220/230 and shut it off and it didnt burp the coolant level is the same, and my TOP radiator house isnt warming up its staying very cool.
Old Aug 25, 2016 | 04:12 PM
  #48
s14hunter's Avatar
Wait for it to cool down, then take the upper radiator hose off the radiator side and fill it up with coolant, then put it back on the radiator. Then go for a drive to get the coolant moving around. Then let it cool down, and check the level again.
As for the degas tank setup, the ball shaped tank on my car is from a 1999-2004 VW GTI 1.8T. The tank in that last pic is from a 1998 Ford Taurus. There's all sorts of degas tanks out there, you just have to find one that fits your application. If you end up going that route, feel free to message me with any questions you have.
Old Aug 26, 2016 | 05:51 PM
  #49
Tanmanls1's Avatar
Gonna order the ls3 water pump I hope it fixes the issue!
Old Aug 28, 2016 | 04:31 PM
  #50
joecar's Avatar
Do you have a thermostat installed...?
Old Aug 29, 2016 | 09:52 AM
  #51
Tanmanls1's Avatar
Yes Sir.
Old Aug 29, 2016 | 02:39 PM
  #52
jimmyg's Avatar
Turn the heat on . You probably need a 4 way mixer valve . The coolant needs to flow behind thermostat to operate properly. Jack car up in front, turn heat on and run with cap off while squeezing rad hoses . Another way is to use a no spill funnel 30$ Amazon
Old Aug 30, 2016 | 01:28 AM
  #53
joecar's Avatar
LS thermostat does require heater circuit to have continuous flow.
Old Aug 31, 2016 | 07:56 PM
  #54
Tanmanls1's Avatar
My heater doesnt work. No air comes out..
