Steam Vent Conflict -
Old Aug 29, 2016 | 11:06 AM
ewingr's Avatar
Default Steam Vent Conflict -
I purchased a Steam Vent kit for my LS3 . Turns out that it really isn't suited for the LS3.
As you will see in the picture below, the plastic tube that connects a port from the manifold to the engine runs right over the vent on the passenger side.
I think I can make it work if I run just a rubber hose in place of the OEM plastic hose. Anyone see a problem with that? Or is that port pressurized, which might blow of a non-barbed rubber hose?
If I end up unable to use that, I will need to purchase a new OEM steam vent crossover and just use that. I'll put a WTB in the For Sale area in that case.
Old Aug 29, 2016 | 12:39 PM
Project GatTagO's Avatar
What's wrong with the stock crossover tube?
Andrew
Old Aug 29, 2016 | 01:06 PM
s14hunter's Avatar
Just get some rubber PCV hose at your parts store and loop it around the steam port setup. Just make sure the hose doesn't kink up.
Old Aug 29, 2016 | 03:46 PM
Pop N Wood's Avatar
Yes it is pressurized so you need to get the appropriate rubber hose. I use a small section of rubber hose to connect the stock "coolant bypass tubes" to a fitting I tapped in the water pump.
Old Aug 29, 2016 | 05:22 PM
L92 OLDS's Avatar
Andrew
Agreed. Why remove the factory steel tubing and put the goofy kit on it?
Old Aug 29, 2016 | 06:24 PM
kwhizz's Avatar
That's the PCV Hose..........Not the Steam Vent.......
Old Aug 29, 2016 | 07:21 PM
ewingr's Avatar
OK. I have it figured out.
Why change? Well, in retrospect, there was no need. When I built my LS1, I needed to make a change. At that time I followed some suggestions I found back then (2005), which was to run it to my water pump. I think that actually causes some problems. I've seen reference to that making the engine run cold, and in fact mine does.
So while preparing for what all I need to do for the LS3 install in my 61, I had recently run across the article about this kit. On Jegs, they sell the kit also with a radiator hose adapter to use with the kit-> here.. It seems that putting it there, or at the radiator, is the currently suggested method.
So, I purchased that kit.
But, I could just have easily taken it from the OEM/original steam vent aparatis.In fact, as I started on this, I looked at that and thought "I should probably use the original".
Why was it bad? I took a lazy route (most often not a good thing) and cut the original to take it off, to save pulling the intake. So, it can't be used.
All that answered, I have swapped sides for the vent connectors, and am going to be able to make it work.
And after all that, looking at the above picture, I realize I need to pull the intake and clean it out.
Thanks, everybody, for the input.
Old Aug 30, 2016 | 07:33 AM
Nali6.2's Avatar
where did you get the parts for the steam ports?
Old Aug 30, 2016 | 08:59 AM
There is a link in post #7...
Andrew
