throttle becomes unresponsive at wot
1. P0717-Input/Turbine Shaft speed sensor "A" Circuit no signal.
2. P0705-Transmission range (TR) switch circuit
3. U0140-Lost communication with body control module (BCM)
Now what would cause this? Bad sensors? Its a junkyard transmission. Or is it something with the wiring to the brake switch? It runs fine otherwise.
ISS issue is either in the tune, wiring, or a bad sensor. Verify the ISS and VSS wiring are in the proper location of the 4L80E. The VSS and ISS connectors are identical.
Give us a call and discuss your options. 765-378-4908 My name is Justin.
