Best Value LS3 Swap?
I've driven an new corvette too, as mentioned above, which weighs less and might make a little less power. The instant torque is nice, but the torque from the turbos spooling on the S4 is more fun. If I did an LS turbo though, I would have to control boost onset to avoid blowing the tires off which would limit that fun.
I don't know, I've been casually thinking about this for months and it's been hard to decide NA vs FI or if an LS swap is worth it over a built SBC.
The audi is a little different, so I'm not sure how it would feel. It should make low 400 wheel tq around 3300rpm and taper down. That's why I was looking for 500whp/tq at least, so it wouldn't be close, but hopefully still be steetable.
If the Camaro was AWD, I would no doubt go FI and big power. I don't want to overbuild for a RWD car on the street though.
I wouldn't change out my 4L80e for any other trans even if someone was doing it all for free and giving me the transmission. That's the beauty of a programmable transmission. I can change how it upshifts/downshifts and what RPM/Speed/Throttle% that I want.
That will really give you a better feel for what direction you should go. I love a manual transmission personally, but that has nothing to do with how an auto performs its just a preference of mine.
That said, I'm guessing adding a turbo isn't as easy as some make it sound. My Audi has multiple solenoids that control the boost. Would the LS just be controlled by the wastegate and boost controller?
If I do that, I'll probably go 4L80E. A T56 magnum kit is over $6k and would need a strong/probably not street friendly clutch or twin that wouldn't be cheap or last long.
Can I just put a cam in and run it stock up to ~700whp? Pistons and rods will be fine, or should I build a forged rod/pistons block? It looks like building is a significant cost increase from the crate engine. Is the compression low enough stock?
Andrew
Here is something I did recently, and it didn't even need the advanced ICF...
https://ls1tech.com/forums/conversio...l#post19379715
Andrew
