12 mpg, running rich?
Anything I can check before I call psi? should I take it to have a tune done? what can I test?
3000lbs with that engine should give you around 28mpg highway cruise minimum. I can do 32mph with 2800lbs and a 9.3:1 LSx finely tuned (15.2:1~ cruise open loop)
Plugs should all look clean, white with a tiny bit of tan, almost new for at least 10,000 miles of driving. Use a quality plugs and filters (oil and AIR FILTER very important). Make sure you use as much gap as possible (better/complete burn with a larger gap).
Lots of things affect fuel economy, I have become an expert at achieving mileage. Here is a short list that can alter economy in no particular order
injector phasing(spraying through overlap), alignment, tire pressure/compound, rolling resistance in general, brake drag (push the car, does it push easy?), overdrive/lockup (in your case, gearing and cruise RPM should be fine), ignition timing (should be 35-40* btdc during cruise for most engines on 93 octane), a/f ratio (closed loop is fine for novices but slight greater economy, 2-5% can be achieved with open loop finite tuning), I am forgetting some things (its on the forum in my other old posts if you dig it up, related threads)
