Want more performance and improvements in Horse Power
How can i get more power, I am just trying to get more ideas and info to get guided in the right direction for more power out of my setup, I have a 1994 C 1500 short bed single cab originally had a 5.7 liter I did a LS swap from a 2012 Texas Edition Silverado with a 5.3 liter and also with a 6-speed transmission that came with it , I have short tube headers and it has a pretty good tune, right now it only spins one tire so I want to install the Eaton Detroit Truetrac Differential and maybe change the shortys with some long tube headers and an X-pipe installed , any other ideas or mods I can do to get more power out of my setup. I use it as a daily driver but also Street truck for street races
Camshaft swap and torque converter swap will make huge difference in performance.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic302845_6.gif)
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
I also have a really clean 1996 Z71 Chevy truck but 20 years ago swapped in a low mileage LT1 from a Corvette. It's a great runner but I wish I would have waited and gone with a LS motor so I could add a turbo. I still might swap in a used 5.3 and turbo it. It is the biggest bank for your buck and these trucks have a lot of under hood space for it.
BTW, good advice above regarding adding a posi carrier and quality torque converter. My truck has 3.42's / 700R4 with a stall and Auburn pro posi. The (2) latter additions made a big difference. With your 6 speed auto you may not need the stall as much.
I'm in the process of putting a warmed over LT1 out of a ImpalaSS (95 Got it for free) in my 94 1500SWB truck. The reason i chose it was because everything fits. ported heads 1.6 roller rockers Howard Cam. Should move the little truck right along...
