ls1 Chevette
Old Nov 7, 2018 | 05:05 PM
  #161
Romulus22's Avatar
Thanks again guys.
Heres a picture of the car when I first bought it, compared to now. Pretty much nothing different exterior but it looks so much tougher on the welds.
Old Nov 7, 2018 | 08:29 PM
  #162
Project GatTagO's Avatar
Nice! Getting some 1320Video love.
Andrew
Old Jan 29, 2019 | 10:09 AM
  #163
sbauerz28's Avatar
What are you using for a torque arm, F-Body? Do you have any pics showing where it's mounted?
Old Jan 29, 2019 | 11:01 AM
  #164
Romulus22's Avatar
It’s a modified length to fit Chris Alston 60’s Cougar torque arm for a 9”. Mounted up on the trans mount using the scrap steel I had laying around in my garage. It looks worse now that it’s a power glide car and I lost the ability to tie into the tail of the trans. Here’s a few angles of what I had in my phone.
Old Jan 29, 2019 | 11:08 AM
  #165
Romulus22's Avatar
Forgot a picture
Old Jan 29, 2019 | 11:53 AM
  #166
sbauerz28's Avatar
Thanks for the photos! I've been trying to decide on how I want to set-up the rear suspension on my next Chevette. I had ladder bars on my last one, but I didn't care for how it rode on the street. I though about a 4 link too, but I don't like the idea of losing my back seat. I want to keep the interior somewhat stock. Your set-up seems to work good. I've watched your videos and it looks like it leaves the line good.
Old Jan 29, 2019 | 04:08 PM
  #167
Romulus22's Avatar
I plan on going ladder bar on my next setup for simplicity and ease of packaging. This setup isn’t bad and it’s probably more capable if I knew what I was doing more. So far my best 60’ is a 1.44 on a 24.5”x8” tire
Old Jan 29, 2019 | 06:10 PM
  #168
Why did you lengthen the torque arm? I always thought that shorter arms tend to be better for drag racing.
Andrew
Old Jan 29, 2019 | 06:57 PM
  #169
Romulus22's Avatar
My knowledge of what is better than what is pretty limited. I just copied how an F-body torque arm goes all the way to the pivot of the front I-joint. I thought that’s how it had to be when I was building the car. This was before I knew anything about ladder bars setups.
Old Jan 29, 2019 | 09:39 PM
  #170
I just remember a buddy that had a 3rd gen Camaro and when he was building his car for serious drag racing he had a custom, much shorter torque arm installed. I don't know what's "best" either...LOL
Andrew
Old Feb 2, 2019 | 07:12 AM
  #171
Mr.Bu's Avatar
Shorter will hit the tires harder. Height plays a role too. Higher will give you more weight transfer so have at it if you want to flip over lmao. This is a really cool car.
Old Feb 2, 2019 | 05:13 PM
  #172
Romulus22's Avatar
Next season I plan on trying a set of 25”x 9” tires. I’m hoping I can squeeze them in at least. I just start tuning in the rear shocks last season. I’d like to touch a 10.3 with the car how it is right now. I’m working on building a garage and if I can get that built this car will have a serious rebuild in store.
Old Feb 3, 2019 | 09:30 AM
  #173
Mr.Bu's Avatar
you should easily be able to hit that. Your 60 is off at least .5. Is your converter real tight? Low 60 but “highish” mph would indicate that.
Old Feb 3, 2019 | 12:07 PM
  #174
Romulus22's Avatar
It has. “3500” stall but stalls around 5000 on the brake. I haven’t tried leaving on stall yet. I have an msd set around 4100 and that has produced my best 60’so far.
Old Feb 12, 2019 | 04:57 PM
  #175
sbauerz28's Avatar
I picked up another Chevette last week and I’m getting ready to order some rear wheels and tires. I’d like to try a set of 26” tires. Do they fit the wheel well ok? I’ve done some measuring and they look close. I ran 24” tires on my last one.
I want to try a 275/50r15 on a 10” wheel. I’m not worried about the width. I plan on mini tubing it. I’m just worried about the length of the opening. I don’t want to stretch the quarters.
Old Feb 12, 2019 | 06:25 PM
  #176
Romulus22's Avatar
I was pretty sure I measured the tire at Walmart as a 26” tire not mounted. As the car sits it’s 25” from ground to top. They are 215/65/15. Here’s a bunch of pictures, they are pretty stuffed front and back.
Old Feb 12, 2019 | 06:36 PM
  #177
Romulus22's Avatar
Picked up a couple “new” gearsets for next season, or I might just hold off until I do my rebuild.
Old Feb 19, 2019 | 10:34 AM
  #178
sbauerz28's Avatar
What size radiator do you have? Is it a 22X19? I think that's what I had in my last Chevette. I just want to avoid any overheating issues since I plan on driving this car alot on the street when it's done.
I'll start a build thread on my car someday soon when I start making some more progress. So far, I've got a Chris Alston's Chassisworks 4 link, 275/50R15 ET Streets, 15X10 Weld Draglites, and my 2001 LS1 dropout is on the way. I drove from New York down to North Carolina the other week to pick this car up. 100% rust free body and floor.
Old Feb 19, 2019 | 07:08 PM
  #179
Romulus22's Avatar
I’m using a speedway motors 19”x24” double pass radiator. Part# 917-340-24
using a single fan” not sure the size but it’s def smaller than 19”, and no shroud I’ve had no issues street driving it even in the summer sitting in rush hour traffic on the highway.
Old Feb 20, 2019 | 08:22 AM
  #180
sbauerz28's Avatar
Thanks for the info and part number!
