AC wiring with ECM control clutch/fans
A lot of the ECM circuits use 5VDC. The compressor clutch relay is 12VDC, the ECM provides a ground for the relay, Relay has the 12 VDC positive for the coil waiting for a ground. The compressor clutch requires strong 12V, thus the reason for the relay.
EDIT See previous post #19, Thanks Ls1nova
Ls1nova71 thank you! From what I hearing from you my 2007 express van pcm should work just fine for me.
In my original system I only have one switch a binary witch . I don't think I have a low pressure switch . Does this mean that I have to plum and install a low pressure switch and give that signal to my pcm ?
