94 4L60E Transmission
Old Oct 16, 2016 | 12:43 PM
Birdracing's Avatar
Default 94 4L60E Transmission
Will a 5.3 LM7 bolt to a 94 4L60E Transmission or does it have to be OBD2??
Old Oct 16, 2016 | 01:20 PM
tfi racing's Avatar
It can bolt up with the right combo of flexplate and spacer,but the pcm cannot control it.
Old Oct 16, 2016 | 01:23 PM
Isolde's Avatar
You can use it, it can be bolted together, choose a converter for the trans, then use a flat 4L80E flexplate with the 0.400" aluminum spacer.
Just tell whoever tunes your pcm so they can make it all work together. PWM was introduced mid-94, so chdck the front pump, behind the converter, before final assembly or the baseline tune.
Old Oct 16, 2016 | 03:48 PM
Birdracing's Avatar
Thank-You for the replies i thought i would have to buy another tranny seeing that i just got this one done a few months ago.
Old Oct 16, 2016 | 06:38 PM
Isolde's Avatar
I did exactly this, with the 4L60E from a 97 C2500 van with the L30 Vortec 305, which had the integrated bellhousing and PWM, my tuner guy had no trouble getting it to play nice with an '01 4.8L, and I was using the 2075-RPM-stall torque converter from a '99 L35 S-Blazer 4x4.
I won't recommend the guy I used, but since he managed it, others can also.
