Looking for help on cam specs??
Old Oct 18, 2016 | 04:13 PM
Nc67lsx's Avatar
Question Looking for help on cam specs??
Hey Guys, so any and all help would be appreciated on this topic.
This is my 1st ls build, Texas speed is currently building me a 408 built for boost. Coming to the point where i need to pick a cam, so looking for advice in which way to go. Going turbo or procharger, undecided still.
408 iron block, 4.030 bore 4.000 stroke, wiseco pistons,prc ls3 260cc heads.
Car weighs about 3000lbs, turbo 400, dana 60. Thinking between 3.73 or 3.50 gears depending on sizes for the dana. Cars fully tubed, and the stall is a 3500 i believe. Car will run on 93 pump gas with an additional tune for more. Going fuel tech efi for stand alone system. Appreciate any reccomendations on a cam.
Thanks for reading.
Old Oct 19, 2016 | 10:34 AM
jimmyg's Avatar
You should post this in the forced induction section, but off the top of my head I would look at Brian tooley racing
Old Oct 19, 2016 | 12:14 PM
squarles67's Avatar
In my opinion you need to decide whether it will supercharged or turbocharged before you pick the cam.
