Ls swap wiring help
Old Oct 19, 2016 | 01:03 AM
1989iroc's Avatar
Default Ls swap wiring help
Doing an ls1 swap in my 89 iroc, I have my painless harness installed and everything seems to be hooked up correctly but when I turn the key to crank the engine it's like the battery is dead, tried a new battery so that's not the issue, could this be the vats? I'm using the ecm that came with the painless harness that's supposed to have the vats disabled, anyone have any ideas, and if it's the vats how do I delete it? Thanks in advance
Old Oct 19, 2016 | 03:41 AM
ls1nova71's Avatar
I doubt its the VATS thats keeping it from even cranking, you would need a starter relay and usually in a swap harness that isnt included. Does it click or anything? Is your neutral safety switch hooked up? Is it in park?
Old Oct 19, 2016 | 04:44 AM
1989iroc's Avatar
There's a t56 in it, i didn't know about the starter relay, I don't think there's one on it now, it doesn't click or anything
Old Oct 19, 2016 | 08:25 AM
ls1nova71's Avatar
Have you xhexked to see if you're getting power to the starter when trying to crank it?
Old Oct 19, 2016 | 08:57 AM
JoeNova's Avatar
Restricted User
VATS has nothing to do with it not cranking.
Old Oct 19, 2016 | 09:00 AM
1989iroc's Avatar
There's power to the starter, I'm thinking it may have something to do with a ground
Old Oct 19, 2016 | 09:05 AM
JoeNova's Avatar
Restricted User
The starter needs power from the battery, and then power from the ignition switch/starter relay.
If it has power straight from the battery (or alternator), then your problem is in the ignition switch or starter relay.
Old Oct 19, 2016 | 09:11 AM
ls1nova71's Avatar
You're getting power to the starter on the purple wire going to the starter solenoid while trying to crank it? If so, your starter is no good.
Old Oct 19, 2016 | 09:32 AM
1989iroc's Avatar
The starter is brand new, I have a guy coming to have a look at it now that knows a lot more about wiring then I do
Old Oct 19, 2016 | 09:44 AM
1964SS's Avatar
If you've got a jumper cable try jumping the main starter hot lead to the smaller terminal that the purple wire is on. This should bump the starter over. You can probably even do it with an old screwdriver (Just don't ground it on anything!) lol
My guess is you have no hot line from the ignition switch.
Old Oct 19, 2016 | 12:31 PM
cooperhw's Avatar
Did it have a manual transmission before the T56 swap? If so, there may be a switch that needs to "see" the clutch being depressed. If not, there may be a neutral safety switch that needs to be completed/adjusted/jumped across.
Old Oct 19, 2016 | 12:57 PM
1989iroc's Avatar
It was manual before, got it figured out now, was a problem with a ground and had to run a jumper for the neutral safety switch, it runs finally
Old Oct 19, 2016 | 01:08 PM
EddieGoesFast's Avatar
Double check your grounds...make sure they are well grounded.
