2000 LQ4 to TH350
Old Dec 5, 2016 | 07:12 PM
hpfiend's Avatar
Default 2000 LQ4 to TH350
Hey all-
I have done some research and apparently with this engine and the stock flexplate I will not need a spacer or adapter.
I have read I may need to elongate a few holes in the flexplate which I am not crazy about the Idea of slop?
The 4l80 converter was 6 bolts and the th350 converter looks a lot smaller and only 3 bolts?
Old Dec 6, 2016 | 09:51 AM
hpfiend's Avatar
Anyone?
Old Dec 6, 2016 | 10:02 AM
billymgb1000's Avatar
I drilled the holes bigger in the original flex plate and bolted a turbo 350 to her and I have had no problems for 4 years. I even put a stall converter in 2 yrs ago and still no issues. instead of elongating the holes I put in on my drill press and just drilled the holes bigger and kept testing it against the converter till she fit. Good luck brother
Old Dec 6, 2016 | 10:40 AM
rworcester's Avatar
Yep I slotted the flex plate holes on my flexplate while it was seated in a TH350 torque converter so I had a good true center. No spacer needed for the longer crankshaft.
Old Dec 8, 2016 | 02:04 PM
hpfiend's Avatar
I was wondering about this- is there a depression for the tabs or how did you "seat" it to make sure it was centered? Did you guys use a carbide bit in a dremel tool to slot the holes?
Old Dec 9, 2016 | 01:10 PM
74novacustom's Avatar
I used a 5.3 Flex with a Hughes Spacer and elongated the holes with a drill bit. all on my 6.0.
Old Dec 9, 2016 | 03:38 PM
hpfiend's Avatar
Thanks! How did you center it?
Old Dec 9, 2016 | 11:11 PM
aod92's Avatar
I have a 99 lq4 bolted up to a turbo 350 with no spacer.
Old Dec 10, 2016 | 01:46 PM
hpfiend's Avatar
How did you make sure the torque converter was centered on the flex plate when you drilled/slotted the new holes?
Old Dec 12, 2016 | 08:35 AM
rworcester's Avatar
Its a very snug fit on the torque converter for the LQ4 flexplate. I Believe it has 3 or 4 tabs that slip onto the torque converter snout. I slotted my holes with it on the torque converter sitting on a table.
Old Dec 12, 2016 | 10:06 AM
jimmyp3353's Avatar
I have an LM7 with an LS1 flexplate to TH350 and I had circle D custom make a Torque converter for me.
Old Dec 12, 2016 | 08:00 PM
hpfiend's Avatar
I will have to take everything off to look at it as I don't see how it is going to work at all- thanks
